Laars Endurance ebp have hot water but not heat
I have a Laars Endurance combination boiler (EBP) recently had no heat no hot water and kept getting F4 error code. Technician changed flow (supply) sensor. Didn't correct the problem so they changed the internal or system pump. Now I have hot water but no heat. Please can anyone help??
Check the valve actuator honeywell zone valv
Posted on Dec 02, 2010
What is the best boiler for heating and hot water in Europe for a flat?
I would suggest the Wilford boiler is a great option. In particular, the Zhangjiagang Wilford Boiler as it is a combination boiler meaning it is small, can easily be stored in a cupboard and is economical to run. Get in touch with them to see if it is ideal for you.This brand of pressure hot water boiler is the best choice of transforming of the heating boiler of coal-fired. The horizontal structure of the boiler can absorb the heat with high efficiency ,heat transfer fully, the efficiency of heat transfer can reach 98%, and with good quality of steam, not pollution, no noise ,is the real green and environmental protection product. you can go its website for more
Hot Water Boiler Hot Water Boiler Products Hot Water Boiler Manufacturers...
May 08, 2017 | Miscellaneous
Tip
Combi Boilers Waste Energy
Combination boilers are called just that because they combine your hot water production and your space heating together with one boiler. The problem lies in the way that they produce hot water. To make the water hot, these boilers have a coil inside the chamber that the water for the space heating is held. The heat is transferred through the copper coil wall from the one water to the other.
The heat transfer of the efficiency of the transfer is not the problem. The problem is that you have to keep the boiler hot all of the time to make sure that you will have heat to make the water hot when you need it. To compound the problem you will find that boilers are typically very poorly insulated. The amount of heat that you will lose because of this poor insulation is unbelievable.
You have or are thinking about buying a Combi Boiler. Read this first because I will explain to you why you either have or are going to make a very big mistake.
Rather than go with this method of water heating, set up your boiler with a separate zone for an indirect water heater. Indirect hot water heaters transfer heat just as effectively, and they are usually very well insulated. The temperature drop in these indirect tanks is typically less than 1 degree F per hour. That’s not very much!
Keep in mind that even though this setup may cost you a bit more up front, that in the long run you will be saving more everyday. With the price of heating fuels going up daily you can bet that the indirect tank will pay for its self in a very short period of time.
on Dec 24, 2009 | Heating & Cooling
I need to know what P1247 means
this is hard to tell you when i have no year car or make or engine or model but il take a shot at it, p1247, this must be a newer ford with a 7.3 diesel engine, now am i doing? great the 1247 is low boost preasure, make sure there are no leaks on the pipes and gaskets to turbo or the exhaust, then remove the ebp sensor and clean also remove the pipe and clean out then reset your codes and drive. the ebp,exhaust boost preasure sensor. hope this helps also check the linkage to the waste on the turbo that sometimes falls off.
Aug 29, 2010 | Ford F-250 Cars & Trucks
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pool heater not heating water - don't know model number
sounds like manual bypass spring broken or weak remove inspect if ok see if you have valve bypass should only be open half way or close all the way
May 21, 2009 | Jandy Laars Lt 250,000 Btu Heater
Propane Furnace "LO"
if you are not trained for this call pro .but you can check outside where it exhausts and make sure you dont have a load of ice blocking your intake or exhaust to boiler the only other thing for you to check is a blocked condensate drain
Feb 01, 2009 | Heating & Cooling
Heating & Cooling Logo
857 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
