Question about LG 37LG30 37 in. LCD HDTV
32LC7D LG tv has pastel vertical lines running through it. Can't see picture but can still hear sound. Occasinal flicker of picture but then mostly lines.
  • pattoningene May 15, 2010
    Previously I had listed the model of my tv wrong and it was suggested it could be the inverter board, why would this answer be completely different than the other?
  • 566 Answers
Hi patton
To answer your first question;
The problem you have is caused by the lcd controller also called t-con board.
To answer your second question;
That is because the first guy you talked to didn`t know any better.
Posted on May 15, 2010
  • Jacques Marin
    Jacques Marin May 15, 2010
    Are you still with me?
  • 10,594 Answers
It seems LCD Panel problem and I'm afraid, lcd panel will be replaced to fix the problem.
LCD Panel (screen) is unrepairable part and only option is to replace it.
Let me know if you have additional question.
Thanks.
  • Shahid Electronics
    Shahid Electronics May 15, 2010
    I do not know what was previous question, my answer based on symptoms that you said in current question.
    If back light inverter board got failed, tv wont show you even these distorted lines.
    Thanks.
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Why is my LG 32LC7D TV taking 5 minutes to have a picture when turning on.?
Likely signs of a issue that is going to only get worse---could be in power supply of set (first place to look) or could be main board or something that it controls.
Kind of like "My car runs rough when cold" it is a issue that is not full blown yet.
Jun 01, 2012 | LG 32LC7D Television
My LG 32LC7d TV has a white screen with different colored verticle lines running through it, it wont respond to any buttons. Powers on and then right back off. What is wrong, can it be fixed?
You may have muiple problems, the vertical lines can be caused by bad T-CON board or LCD panel, buttons do not response can be caused by bad main logic board. In this case, you need to inspect the power supply module first since poorly filtered DC can cause a lot of strange symptoms.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Aug 02, 2010 | LG 32LC7D Television
32" 32lc7d after a few minutes, flickers, then goes dark.
There are no fans in this model but it looks like either the backlights in the screen are breaking down after they have warmed up or a problem in the inverter board, again part of the driver circuit breaking down after a period of time. They inverter boards can sometimes be replaced seperatly but usually come with a new screen which if the backlights are at fault then the screen would need to be replaced.
Feb 04, 2010 | LG 32LC7D Television
My TV turns on with a alot of colored vertical lines. After it is on for about 15 minutes, you can turn it off and then back on and everything is okay. What is wrong with it?
convergance issue. Possibly bad high voltage transformer or a bad capaictor or IC or STK depending on what type of tv you have. If projection, then STK, if lcd or plasma, then it is an IC
Oct 13, 2009 | LG 32LC7D Television
Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Tv repair
You don't have to buy a new tv, it is a fairly simple problem, your vertical ic is blown, and it could be the powersupply to the vertical ic also. To verify, slightly increase the screen voltage, and a horizontal line will appear on the screen, if the voltages is okay, change the ic, but first try resoldering the ic pins. Good luck
Jan 14, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
LG 37LG30 37 in. LCD HDTV Logo
100 people viewed this question
Computer Repairing
Computer Repairing
