Question about Microsoft LifeCam VX-3000 Web Camera
Port does not have enough power. Tried installing and startiong the webcam. got this message
  • Microsoft Master
  • 11,800 Answers
Only fix - get a powered USB hub, plug it in an open port and the camera in it. Something like
http://www.newegg.com/Product/Product.aspx?Item=N82E16817334015
Posted on May 15, 2010
Hi, im using window vista and my package and my webcam was working (cyberlink youcam) after some times, it has not been working for the past 3 months , i have tried all efforts n do lots of installation...
Have you tried plugging in the webcam to a different USB port on your computer? If not,then try it on
all the available USB ports and check if it works.
Nov 26, 2010 | CyberLink YouCam
Can't make webcam work on Acer Travelmate 4500
This sounds like a USB issue. Not all USB ports on laptops are created equal (they should be but they are not) some usb ports supply enough voltage and current to run usb items properly and some dont. It is always better to run direct from the computer / laptops ports .
If you cant do this then use a HUB but make sure the HUB HAS IT"S OWN POWER SUPPLY !
Also make sure you always use the same port and swapping them around does not always work for all hardware.
Aug 09, 2009 | Microsoft LifeCam NX-3000 Personal Web...
Very long time to install lifecam 2.04
Did you use the CD software program that came with the camera?
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 21, 2009 | Microsoft LifeCam VX-6000 Webcam
Error Unable to start webcam(Philips SPC525NC Webcam)
Try disconnecting the camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work. Hope this helps. Bud
Jan 20, 2009 | Veo Connect Webcam
I have XP Serivce Pack 2 installed, trying to install webcam
have you tried a later version of the drivers from Logitec
install sp3 for xp
remove USB cam from PC before installing drivers and wait for it to ask for the cam to be plugged in , always use the same port (dont ask)
hope it helps
Dec 30, 2008 | Microsoft LifeCam VX-3000 Web Camera
Not enough memory to complete instalation ?
maybe delete some unwanted programs and files off the hard drive you use, you may be out of space on your hard drive
hope this helps, if you need more assistance contact me please.
Dec 03, 2008 | GE EasyCam Pro Webcam
Canon IP2200 ports
Offhand, a couple of ideas, queries and suggestions:
  • verify the USB is enable in the CMOS/BIOS settings/configuration;
  • verify that there are no yellow or red markings in the Device Manager particularly the Universal Serial Bus Controllers;
  • try re-installing the printer drivers with your anti-virus temporarily disabled;
  • try re-installing the printer drivers with the printer not physically connected to the USB ports. Connect printer only when instructed to do so, Reboot;
  • update your Operating System;
  • pls humor me, tried a spare USB cable?
  • have you tried the printer in another PC?
  • have you tried other USB devices such as webcam, flashdrive, digital camera?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 20, 2008 | Canon PIXMA iP2200 InkJet Photo Printer
Webcam Plus... can't get it to work with IM
Hi, 1. Verify your internet connection. If it is possible change your DNS IP Address. 2. Try Updating your yahoo messenger >> http://messenger.yahoo.com/download.php THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps
Sep 23, 2007 | Labtec Webcam Plus 0403
Usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Apr 29, 2007 | Logitech QuickCam Pro 5000 Webcam
Microsoft LifeCam VX-3000 Web Camera Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
