Question about Motorola Walkie Talkie 2-Way Radio
My motorola xtr446 has an icon stuck on it and no one else can hear me when i speak out? how do i get rid of the icon? the icon is a mini walkie talkie
  • Motorola Master
  • 1,654 Answers
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
Posted on May 16, 2010
Motorola xtr446 not receiving
Check your interference eliminator code. It must match on both radios.
Best regards.
May 18, 2014 | Motorola Walkie Talkies 2-Way Radio
Xtr446
Sounds like a receiver fault. Could be you need a new filter
Nov 22, 2012 | Motorola Walkie Talkies 2-Way Radio
Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
Jun 24, 2012 | Radio Communications
We have a set of 6 XTR446 about 2.5 years old. 3 of the handsets are (for no apparent reason) displaying the little handset icon permanently and not operating (either to receive or transmit). One of the...
In order to reset the radio, power on while pressing both volume buttons (+ and -) together with the PTT (speak) button, until you year a high-pitched tone.
But I have found that the "stuck on receive" problem is related to the battery voltage: non-rechargable AAA or incorrectly charged batteries can give 0.2-1.0V above the nominal voltage. Try to leave the radio on for a few hours or replace some of the four AAA batteries with slightly exhausted ones and see if that helps.
Jan 11, 2011 | Motorola Walkie Talkie 2-Way Radio
The 'mute' button is on the radio and I can't get it off. The model of the radio is Motorola XTR446. Thanks
Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
The XTR446 does not have "mute". But what you might be experiencing is a problem with the radios matching one another completely, such as the "interference code" being set differently among the radios. Check your frequency and code to see that they match the other radios exactly. Also, check your radio's mic hole for dust, dirt or debris. This can mute/muffle transmissions.
If this does not solve the problem, you may have a radio in need of repair.
Best regards.
Sep 28, 2010 | Motorola Radio Communications
How do i get rid of the walkie talkie icon on the screen of one phone that is now not receiving. motorola xtr 446 walkie talkie
how do i get rid of the walkie talkie icon on one of the handsets that is now not recieving ?
May 31, 2010 | Motorola Lands Phones
Cannot transmit
You have to tern of function scrambler or CTCSS privacy code. To make this use the menu
Apr 11, 2010 | Motorola Walkie Talkie 2-Way Radio
Walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
Feb 06, 2010 | Radio Communications
Motorola xtr446 can not get rid of icon on phone that has disabled speaker
You may be referring to the circle with a slash through it, which is the scramble emblem. Here is a link to the user guide http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Refer to page 41.
This may help you resolve your issue. Best regards.
Dec 12, 2009 | Radio Communications
Radio Communications Logo
2,665 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
