Question about Kitchen Ranges
GE XL44 Gas Range
I have a GE JGBS23WEA1WW gas range (1996). Last week everything worked fine. Today I tried to light the burners, oven and broil with no success. My gas dryer, water heater, furnace all work fine but not the range. I ckecked to make sure the oven gas shut-off vavle was on. The glow light burner in the broiler compartment functions and the stove top electrodes appear to be working properly. Can you help?
  • Michael Glatfelter Sr
    Michael Glatfelter Sr May 02, 2008
    I came home from work today and the XL44 is beeping loudly and displaying F-1 error code. I cannot get it to stop beeping or displaying the error meesage. Any suggestions?
SOURCE:
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Posted on Nov 15, 2008
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
Sea Breeze
  • 4656 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
Posted on Jul 04, 2009
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
I have a GE XL44 Gas oven and the burners work fine and everything is getting gas but when i light the oven it will stay on for a little while and then shut off. What could be the problem?
heatman101
Dec 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
XL44 GE oven not working. Bottom burner not getting gas.
You probably have a bad ignitor. If the ignitor does not draw at least 3.5 amps the gas valve will not open. This is a safety feature.
Nov 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44 stove
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
233 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
