Question about Kenmore Elite 45986 Front Load Washer
Can I wash plastic shower curtains in my washer if
Can I wash plastic shower curtains in my kenmore model 592 493040 washer if so what program do I use
4 Suggested Answers
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 1937 Answers
SOURCE: my kenmore washer model # 11020952994 washes
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20952994
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site for your washer may have a section on the gearcase. Check in that section for a Neutral Drain repair kit.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Oct 04, 2009
SOURCE: ignis washer/dryer AWF 592 does
WONT PUMP OUT WASTE WATER
Posted on Jan 04, 2011
It swallowed a shower curtain and can not get out
What do you mean by "swallowed"? Is it in the drain pump or under the agitator?
Oct 28, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
I PUT UP A CURVED CURTAIN ROD. IT KEEP CUMMING OFF THE WALL
These rods need a little more support than a standard rod because of their shape. I'm assuming you used a plastic wall anchor in the gyproc or plaster. If so get rid of it and use a butterfly style anchor. The butterfly provides superior support and will allow to tighten the screws more tightly than with the plastic wall anchor. Good luck with your project and let me know if I can be of any further help.
Jul 30, 2010 | Rocky Mountain Hardware Shower Curtain Rod...
Adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Nov 16, 2009 | Rocky Mountain Hardware Shower Curtain Rod...
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
Screechy shower curtain
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
I have clothes stuck under the outer wash plate - how can I get them out?
My shower curtain is partly stuck under the washer plate. I can't pull it out. Who do I correct this problem?
Jan 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Kenmore Elite 45986 Front Load Washer Logo
178 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
