Question about GE Security Simon 3 Wireless Home Security System
When you open the cover the system does not switch mode to programming
    New Friend:
  • 74 Answers
There is a switch that is activated when the front cover is folded down. It sound like that switch is stuck. Figure out what the trigger mechanism is and see if you can "unstick" it. If not you will probably need to replace the motherboard.
AlarmProfessor.net
Posted on Aug 23, 2010
2013 Toyota Highlander. Key fob remote doesn't work after installing new battery. It is not a smart key remote.
PROCEDURE. Make SURE the battery you installed is good.
  • Driver's door open, key removed from ignition switch
  • Within 5 seconds: Insert and remove the key from the ignition switch twice
  • Within 40 seconds: Close and open driver's door twice
  • Insert and remove the key from the ignition switch. Close and open driver's door twice
  • Insert the key into the ignition switch and close the driver's door
  • Within 40 seconds: Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes or twice to program and remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitter are currently registered or five times to erase all registered codes
  • Remove key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
  • Within 40 seconds: Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
  • Within 3 seconds: Press LOCK button
  • SYstem should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
  • Within 40 seconds: Repeat button procedure to program remaining remote transmitters.
  • NOTE: To exit programming mode: Open driver's dorr
  • NOTE: A maximum of 4 remote transmitters can be programmed
If the above programming procedures do not work, then you should contact your locksmith.
Goood Luck!
Dec 13, 2017 | Toyota Highlander Cars & Trucks
My Kyocera mita 2530 copier shows system error C6000 and will not operate
May be a fuser error.
Try....
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on
Oct 28, 2017 | Kyocera Office Equipment & Supplies
Need to reset the key fob on acura 3.5 rl 98 and dont know how
It is a PAIN. You have to be very precise and have good timing. I had to repeat the whole thing about 4 times before it worked. As a side note, a great place to read EVERYTHING about your car is at rl.acurazine.com it is terrific.
• This system accepts up to two transmitters.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all the transmitters once you're in the
programming mode.
1. Open the driver's door.
2. Push up the driver's door master power door lock to
the unlock position. Hold it there for the rest of this
procedure.
3. Insert the key in the ignition switch, then remove it.
Repeat this four more times within 10 seconds.
(Steps 3 and 4 must be completed within 10
seconds, or the system will exit the programming
mode.)
4. Insert the key in the ignition switch. Make sure the
power door locks cycle to indicate that the system
has entered programming mode.
5. Press the "LOCK" or "UNLOCK" button on the
transmitter. Make sure the power door locks (all
except the driver's door) cycle to indicate that the
transmitter has been accepted.
6. To program a second transmitter, press its "LOCK"
or "UNLOCK" button within 10 seconds.
7. Release the master power door lock switch to exit
the programming mode.
Sep 18, 2011 | 1998 Acura RL
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
Loading books into adobe digital editions
There are a few different ways you can add books to your Library with the Adobe Digital Editions program. Once the program loads left click on the down arrow beside the "LIBRARY" menu. In the drop down menu you will find an "Add Item to Library" choice. You would then surf to the directory that holds the books you want to add. You can also open a Widow to the same directory and drag and drop the books from your window to the programs window. You can also go to the numerous websites that support the program (the books must have the "epub" extension) and purchase or download books from those websites. Double clicking any of those files will automatically load the Adobe Digital Editions program as the program sets that default action when you install it on your computer. Once the book is added to your library you will see the cover of the book in your LIBRARY view. Double clicking any of the covers will then load the book and the program will switch to the READING mode for you. In the upper left corner of the program you will see and icon that looks like 3 bookends (LIBRARY mode), and another one that look like an open book (READING mode). This is how you will switch between either adding books or reading the books you have added.
If you have ebooks in other formats there are programs which allow you to change the format of the book to the epub format you need for the Adobe program. Calibre, which you can find at http://calibre-ebook.com/
is an excellent free program which will allow you to reformat books if necessary.
Feb 15, 2011 | Computers & Internet
Remote got wet in salt water. Had battery changed
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 5 seconds: Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch. Close driver's door. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Carry out the following button procedure within 40 seconds: Press key lock or unlock button once. Within 3 seconds: Press same key lock or unlock button once. System should now lock and unlock vehicle.
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat button procedure.
If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Open driver's door. NOTE: A maximum of 4 keys can be programmed
This will work providing printed circuit is not damaged in remote
Jul 20, 2010 | 2004 Toyota Camry
Central locking went on my lexus took it the garage they said the key wouldn't reprogramme is there anything that can be done
Programming
When
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Close and re-open driver's door. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Insert key into ignition switch. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key from ignition switch. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Within 40 seconds: Simultaneously press and hold key lock and unlock buttons for a maximum of 1,5 seconds. Within 3 seconds: Press any key button for a minimum of 1 second. System should now lock and unlock vehicle once.
Manufacturer: Lexus Model: IS 2,0 200 Engine code: 1G-FE Output: 114 (153) 6200 Tuned for: R-Cat Year: 1999-05
© Autodata Limited 2009 25/02/2010 V8.207M-ukad113581
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat programming procedure.
Within 40 seconds: If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Close driver's door or insert ignition key. NOTE: A maximum of 4 keys can be programmed
Feb 25, 2010 | Lexus IS Cars & Trucks
Reset immobiliser
u must put a key to ignition and open a drive door 3 times and press and hold lock button
Jan 18, 2010 | 2007 Ford F
Lock control program after open cover lid of Pioneer PDP434 PG
If you had power this set on with the back off it will not work without closing the switch again and entering serv mode and reactvating . Call pioneer customer serv to get info to reset the unit. Must have pioneer remote to do this reset.
Aug 29, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
Aug 24, 2008 | 2000 Chevrolet Venture
GE Security Simon 3 Wireless Home Security System Logo
44 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
