Question about Toshiba Satellite A85-S107 Notebook
Satellite a85-s107 seems like its stuck in restart mode wont run sytem
Not connect internet and dvd drive
Posted on May 20, 2010
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
On my toshiba satellite a85-s107 have a loose connection at the power plug in so power is constantly going on and off this is at the laptop plug in
The only way to deal with this is take laptop apart to access the motherboard and resolder the plug points to firm up the connection. There is no other way to address this.
Mar 07, 2012 | Toshiba Satellite A85-S107 PC Notebook
I need to know what type of harddrive my toshiuba satellite A85-S107 uses is it sata or pata ??
The type of hard drive that is compatible with that model laptop is IDE/PATA not SATA.
Regards.
Apr 12, 2010 | Toshiba Satellite A85-S107 Notebook
I have a toshiba satellite a85-s107.....got blue screen of death
when ya boot it up...press F8 a bunch of times and try to go to safe mode and try to copy all your files to a hard drive and then put the disk that came with your computer in, and reinstall your operating system and that usually works for me
Dec 27, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite a85-s107 disc drive not working. drive opens takes cds and acts like its reading them but the program never opens
google search a downloaded program called CD BEGONE...run it..reboot pc.
if that does not cure problem....buy a replacement drivefrom ebay
Sep 15, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite a85-S107 the volume control wheel on the computer does not turn the volume all the way down. I can still control it through windows. Help!
maybe your driver is not working well http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm go to this site you can find drivers of toshiba there. reinstall some of your not compatible drivers.
Aug 06, 2009 | Toshiba Satellite A85-S107 Notebook
How do i disable programs from startup or goto default startup?In a Toshiba Satellite A85 Win XP
Type
MSCONFIG in the run box, go to the startup tab
Set as you wish here
Regards
Richard.
May 19, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite a85-s107 laptop
If it makes a either a griding noise or sounds like it's going to take flight, you may need to have the fan replaced. Even after dust collects in the motherboard compartment, or somehwere by the fans, dirt and oils tend to get stuck in the fan and ruin it. Have the fan replaced before it creates more damage. Laptop repair: http://www.computer-repair-today.com
Dec 01, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
