Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Why wont my Jet pump shut off?
Changed pressure switch on shallow jet pump now pump wont shut off. 70lb of pressure and plenty of water.
  • Anonymous Mar 29, 2014
    We hooked up a jet pump shallow well pump model ACE5S1\2HP
  • 8,404 Answers
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
Posted on May 15, 2010
  • A Miller May 16, 2010
    So hwata happened when you tried my suggestion?
Pumps water for a minute then shuts off.
Probably the pump has a water pressure protection switch. So it will not run dry and burn up. How is it that you are losing water pressure? On the delivery end or receiving. Restrictions on a pump always are placed output
Jun 01, 2015 | Craftsman Professional 3/4 hp Hydro-Glass...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Once the water is shut off the pump keeps running
the pump is controlled by the storage tanks pressure switch , if it continues to run well after the pressure tank has refilled with water , either the switches manual override has been activated (lever) or its defective or blocked off with mud
Jun 27, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
Pump will not shut off
could be worn mechanical parts in the pump, or air in the pump. Make sure there is no air leaking into the suction/inlet side of pump.
Nov 14, 2013 | Goulds Pumps 1/2HP J5S Shallow Well...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Air in faucets
The tree may have damaged a pipe,which is letting air into the system. I'm suprised you haven't mentioned a leak. It's possible for air to be pulled in thru the motor seal, if suction is high. High suction usually means trouble in the well, a clogged point or a malfunctioning check. Push on pipes and the pressure line to the switch, if they leak water out, air can be drawn in.
Mar 30, 2009 | Jet Plumbing
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
872 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
