Question about Sony Televison & Video
I have tv Sony KV-1484MTA with unstable view - picture is good or only horizontal, heave line. Please, I need help and also repair manuals with schematic.
  • Bogdan Olejarczyk May 20, 2010
    I change 2 electrolytic caps (c552 and c558). The picture is good now. Best regards, olejarczykb
  • 4,889 Answers
I didn't understand what you meant by horizontal heave line. Do you mean to say that the picture shrinks to a line? Please provide this info so that we can continue with the diagnosis and troubleshoot as necessary.
Sai.
Posted on May 17, 2010
  • 2 more comments
  • Bogdan Olejarczyk May 17, 2010
    Yes, the picture shrinks to a line. If, I a lightly strike in the side of tv the picture is again good. I find R803 and R806 (near IC551) with a bad solder and I corrected it, but still is not well. What can I do more? Best regards, Bogdan
  • eagle338
    eagle338 May 17, 2010
    The problem you have described indicates a vertical scan circuit failure. First think to look for is bad electrolytic caps that are cracked at the top or leaking. I would also check for dry solder joints in the same circuit since the picture is returning back to normal after tapping.
    Thank you very much, I change 2 electrolytic caps (c552 and c558) - picture is good now. But for the future, please send me manuals with schematic for my tv. Best regards, olejarczykb.
  • eagle338
    eagle338 May 21, 2010
    Great to hear that! Thank you for using Fixya!
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Oct 22, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
177 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
