Question about GE WBSR3140DW Top Load Washer
Our washer is not running the spin cycle. It
Our washer is not running the spin cycle. It sounds like the motor is running, but the tub is not spinning. Any ideas?
  • GE Master
  • 5,568 Answers
If the tub is not driven by a belt, the transmission may have failed.
You can check for a broken belt by removing the back panel of the machine which often requires only the removal of a few screws after pulling the AC plug.
Posted on May 15, 2010
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
My washing machine will work on the wash cycle but will not spin.
if no sound in spin cycle, lid switch. if motor is running but no spin, motor coupler is likely. or foreign object is physically holding tub ie nail on tub hole etc.
Jun 12, 2009 | Kenmore 25852 Top Load Washer
The tub will not spin in the rinse cycle
This sounds like a timer problem if it will spin in other cycles. If you hear a motor running but no spin it is the motor couple.
Mar 12, 2009 | Whirlpool Washing Machines
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer wont run but is trying to
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
121 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
