Question about Malber WD1000 Front Load Washer/Dryer
Dryer won't dry
I had the dryer going and i hit the cancel spin -
i then started a new load - wash washed and did not dry;
i tried running just the dryer and it wont do anything?
What could be wrong
ITS BRAND NEW.. 108 DAYS OLD
I also have one for several years now.
I also had problems with dry function at first.
If your washer is still covered by warrenty, call them. They were very friendly and helpful and came out and made service call at no charge.
My problem was that I had attached the discharge hose to an existing discharge pipe that connected to the sewer. This pipe was too narrow and burned out the condenser.
Also, try cleaning out the lint filter on the lower right side of front. Put a cookie sheet under the opening to catch about a cup of water that will come out.
Good luck,
wsf
Posted on Apr 05, 2008
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
I can't turn on SpinSense on my LG WM3987HW combo washer-dryer. I've tried pressing the button for 3 seconds in nearly every mode, on or off, locked, unlocked, wash, spin, rinse. I've managed to get it on...
I have an earlier version of your machine (WM3988HWA). What I've found is that you can't use the Spinsense feature if you've got the Dry cycle set to go after your wash. I have no idea why they designed it this way!
We run the wash first without setting it to dry, and have no problem turning Spinsense on. I usually hold it down for 3 second after hitting the start button, but you can also do it before you start the wash. When the wash is done, then we start a dry cycle.
This is the main flaw with our otherwise great machine. I posted about it at http://www.fixya.com/ThreadAsker.aspx?thid=1844295 a long time ago but never got any advice.
Nov 27, 2010 | LG WM3987HW Front Load Washer / Dryer
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Kenmore 3.5 HE front load washer went haywire, doesn't work now..
Yes - the ECU is to blame, and is a common failure with this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 43042 Front Load Washer
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
GE front load dryer
Clothing gets caught in the front of the dryer as it spins. This is leaving black marks and wholes in our clothing.
Apr 06, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Not spinning after first 3 second spin on start.
You need a new PCB. THis happens often on these machines.
Nov 23, 2007 | Electrolux EW1200i Front Load Washer /...
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
179 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
