Question about Xante CL30 HSE Laser Printer
Transfer belt error 356
My new transfer belt will stop working around 70 % in one cl30 and will contineu to work in another cl30 what is the solution
  • 66 Answers
There is what is called a etb electron static transfer belt in this system if that is what you are referring to then it will be a big cost to six. but if the etb belt ids warn then that might be why it's life was so short
Posted on May 15, 2010
How do i Fix Error Code 2152 Konica Minolta Biz-hub
Code: C2152 Code C2152 Description Transfer belt pressure welding alienation
• During a retraction operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its retracted position within a predetermined period of time after the transfer belt retraction clutch is turned ON. • During a pressure operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its pressed position within a predetermined period of time after the transfer belt clutch is turned ON. Remedy 1 Check the M5 connector for proper connection and correct as necessary. 2 PS31 I/O check, sensor check. 3 CL7 operation check. 4 M5 operation check. 5 Change CL7. 6 Change M21. 7 Change PRCB.
Jan 29, 2015 | Konica Minolta bizhub Office Equipment &...
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
What is meant by error code SC 403
From the service manual:
SC403: Transfer belt position sensor error
-Definition-
The transfer belt position sensor does not activate even if the transfer belt clutch has rotated once.
- Possible causes -
• Main motor/drive malfunction
• Transfer belt position sensor defective
• Poor transfer belt position sensor connection
According to the manual, provided there isn't a major problem with the machine, you can reset the service code by turning off the MAIN POWER switch for a 10-seconds and then turning it back on. This should reset the code provided the problem doesn't reoccur. NOTE: The main power switch is a rocker switch on the front or left side of the machine, not a push-button switch up on the control panel.
Probably not a big help, but hopefully at least a little. I can't offer you much better advice, as I don't work on machines of this age, sorry.
Jan 20, 2010 | Ricoh Aficio 450 Copier
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Need to reset counter for transfer belt
to reset the counter on the toners and transfer belt see:
http://www.dunfield.com/clp510/
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Xante Cl30 laser printer error
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
Mar 26, 2008 | Xante CL30 HSE Laser Printer
Transfer belt unrecognizable
If memory serves me right, after you replace the belt, you power machine on, wait for the error message, open the cover then close it. It should re-initialize the new belt.
If not, try turning it off, open the cover, then turn it on, wait for the "close cover" message, then close cover.
It was some weird combination, but that's how you reset the count.
Mar 24, 2008 | Computers & Internet
Phaser 6100 - lever unlocking error
This printer is same as Samsung CLP-500. So the problem is the same: Contaminated transfer belt sensor.
Do as follow:
Lift transfer belt assy from printer(Drop down back door 90 degree, press white button, lift top cover and release 2 locking levers, grab handle, pull the belt unit out), turn upside down & rotate plastic roller until small clear "window" appears along one edge of belt. Clean both sides of clear window with cotton bud. on same side as window, remove 2 screws securing flimsy plastic cover to gain acess to sensor, (follow red/black wires)remove a screw and pull out "U" shaped sensor(light transmiter and receiver), cotton bud and blow away dust on slits on inner surfaces of sensor. Reassamble and everything should be ok.If not, senser may be too contaminated, clean slits vigorousley with cotton bud, or maybe you just need a new sensor.
The theory is that printer detect transfer belt by transmit light through the clear "window". If either window not clear or sensor is contaminated, light will not reach the receriver part of the sensor, printer will report such errors.
Good luck.
Jan 26, 2008 | Xerox Phaser 6100/BD Laser Printer
Transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Xante CL30 HSE Laser Printer Logo
241 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
