Question about Umax Astra 3400 Flatbed Scanner
Power button seems to have no effect , indicater light is on but windows 7 does not respond saying there is no driver
  • 51 Answers
Sounds like you have a hardware/firmware issue. Unplug any new hardware - reboot - after logging in then replug your hardware
Posted on May 15, 2010
GET OUT OF POWER SAVE MODE
If you have Windows XP VISTA or 7 go to where you select you background. there should be a spot saying power options or so. MY xp is down righ now so I can't say exactly. but when in power option settings you can configure how you want your unit to respond to power usage, balance high performance etc. you can also alter or create your own setting. the time until unit goes to sleep or not at all etc.
If in Windows 8/8.1
right click screen select personalize then go to screen saver bottom right corner. there will be a spot labeled power management click change power settings. Select the option(s)s you want click apply then ok apply tells unit that you want that selection to be active all the time . ok usually effects the time you are on at that moment and doesn't roll-over so to say.
Oct 07, 2014 | Dell Computers & Internet
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Hp pavillion converted into windows 7 ultimate from windows vista and sound does not function. downloaded sound driver for windows 7 but does not work still. please help...
Try 'roll back driver', follow these steps;
- Open Device Manger from the Windows 7 Control Panel.
- In Device Manager, locate the device that you want to roll back the driver for (her its sound driver). (Navigate through the hardware categories by clicking the > icon. You can find specific devices under these major hardware categories.)
- After finding the hardware you're rolling back the driver for, right click on the device's name or icon and click on Properties.
- In the Properties window for the device, click the Driver tab.
- On the Driver tab, click the Roll Back Driver button. (If the Roll Back Driver button is disabled, Windows 7 does not have a previous driver to roll back to so you won't be able to complete this process.)
- Click the Yes button to the "Are you sure you would like to roll back to the previously installed driver software?" question.
The previously installed driver will now be restored. You should see the Roll Back Driver button as disabled after the roll back is complete.
- Click the Close button at the bottom of the device properties screen.
- Click Yes on the System Settings Change dialog box that says "Your hardware settings have changed. You must restart your computer for these changes to take effect. Do you want to restart your computer now?"
DONE, Hope this helps,
Please rate if this solution was helpful, thanks!
Jul 18, 2011 | HP Pavilion dv6000z Notebook
My on board vga driver doesn't support aero effects for windows 7. i tried to update my driver but it says it was the latest driver. i cant enjoy the beauty of windows 7 without the aero effects.. hope you...
You can get the proper driver utility from SIS.com also known as silicon integrated systems it is "sis uniVGA5 graphics driver" version 5.29. I had the same problem as you have: I went to that site and got the program. "NOTE" if you are running stopzilla, UNINSTALL IT BEFORE proceeding!
Dec 11, 2010 | Biostar P4M890-M7 Motherboard
Canon printer error 5100
5100 seems to be a Carriage Home Position Error. Clean the plastic strip that runs the length of the carriage, it may be contaminated. Then load the tray with the blank papers.
Then reset the Printer: Following are the steps:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
This should work. If not, install the Driver and Software from the Installation CD provided with the Printer.
You can also download the Driver from the following link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368#DownloadDetailAct
Select the Operating System installed to download the compatible Driver.
Jul 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Mine is lenovo g430.i use windows 7.the system doesnt switch on.the indicaters and the fan comes on and stays.but nothindg is displayed on screen.
Try to perform power drain first as initial troubleshooting.
Procedures:
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn on the computer
If same issue will happened call our technical support department to have your laptop checked and scheduled for repair. This issue would be an LCD problem.
By the way. Is your unit still under warranty?
May 21, 2010 | Lenovo 3000 N200 Notebook
I am having problems installing canon iP5200 with Windows 7
Did you upgrade the computer from Windows XP to Windows 7? If so, did you uninstall the driver before you did the upgrade? The old driver files may be causing the problem.
To fix, go to this link, and in the search box in the center of the screen type "windows 7" and click on the Search button. Then select the link "ERROR: Cannot communicate with the printer after upgrading to Windows 7". There will be step-by-step directions for resolving your problem.
Dec 29, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Canon IP2000 printer. The power switch is flashing intermittantly green and orange and as a result it seems to be stuck as anything I do has any effect - any ideas?? Many thanks in advance for your...
this may work for you
1. Turn off printer
Nov 29, 2008 | Office Equipment & Supplies
Timer light blinks on and off and tv wont turn on
Resetting the TV
NOTE:
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Umax Astra 3400 Flatbed Scanner Logo
96 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
