Question about Minicraft Models Full Electric Bed - Mattress, Rails
Have Ultramatic bed that remote would not function ,after turning bed on its side to get acess to electronic control unit I noticed a button on the side labeled "LEARN" after sliding this button forward all functions of the bed worked . Is this the botton that programs the remote to the specific bed.Thank you Cliff Law
3 Suggested Answers
SOURCE: Have the genius ultramatic bed.
My head of the bed went up all by itself, the remote had NO battery in it. How do I reset the remote to make the bed go down? It won't work with battery in..... Please advise asap, need to sleep tonight! Thanks
Posted on Aug 01, 2011
SOURCE: Ultramatic bed problem - bed
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Posted on Aug 13, 2011
Where do I purchase a new remote control for the Ultramatic Genius bed:
Just look up Ultramaric Genius bed o -line and they will have an "_800" number. Ask them where may get a remote.
Dec 03, 2014 | Genius Televison & Video
Dvd does not play without the remote pressed play constantly to no avail. what can I do to remedy this?
Something is overriding the Play function. Perhaps on the remote itself or in the machine's hardware switches. Hide all the remotes. Try the front panel Play button. Works? Figure out which remote is causing it.
Still not working? Turn it OFF. Manipulate all controls to make sure they're not 'stuck'. Try again.
Be aware of this:
http://www0.epinions.com/review/Amphion_Mediaworks_T_365_System/content_440913202820
"Recieved unit as christmas present 2007, setup unit enjoyed playing remote radio function, family member shutoff unit using main power button when going to bed, the next day unit does not come on period...the unit was stacked upon vcr and satellite units thought problem was due to electronic heat, but upon further exams, have yet to determine cause...during internet searches, found others having same/or multiple problems..further check tells me company out of business...recommend buyer beware...as repair nearly impossible...unless electronically inclined..tddsim729@yahoo.com"
Feb 05, 2011 | Amphion Mediaworks T-365 System
Ultramatic bed problem - bed will not raise either head or feet - does not move at all. Received replacement remote from company but no different. Lights on remote do not stay on - only when press a button...
Jan 12, 2011 | Minicraft Models Full Electric Bed -...
WIRELESS REMOTE CONTROL - MODEL - r2t3/r2t4. Wonder if you can help please! Have an Electric Adjustable Bed with a remote which has stopped working. Details on the back of the remote are - Model No:R2-T3....
I have a remote for adjustable bed that won't work. I know it is the remote, because I put a new 9V battery in and the red light doesn't come on. Model No:R2-T3. FCC ID: MGB _R2-T (03-680252-03). I see someone posted the same problem and don't see any recommendation to fix or replace it.
Jan 05, 2011 | Televison & Video
Have the genius ultramatic bed. Need to know how to reset?
Dec 28, 2010 | Minicraft Models Full Electric Bed -...
Tempur-pedic remote control does not work have put in fresh batteries - control lights up- but no bed movement Please advise Thank You Carol
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
http://www.tempurpedic.com/media/Ergo_System_Complete_Ref_Guide_FINAL_022008.pdf
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Apr 11, 2008 | Computers & Internet
Dispenser not functioning & control panel inside turned off
you have a bad control board in the rear of the unit ...>>>>> To verify this check for 13.5 vdc on red and black going into the display board?? since your dispenser is not working the control board is most likely not working. puill the refrig from the wall and remove the cover plate it is square about 5"X6" you will see the control board thew part # for this is WR55x10552 if you need to replace it let me know
Apr 01, 2008 | GE PSS26SGR Stainless Steel Side by Side...
Casio phonemate TA120
I have the same machine. There is a Function/Edit button on the upper left hand side of the unit. Every time you press the button you scroll through the functions to program the unit. Change the "remote code" to any two digit number you choose and will take care of your problem!
Apr 06, 2007 | Panasonic KX-TM150B Digital Answering...
Minicraft Models Full Electric Bed - Mattress, Rails Logo
525 people viewed this question
Top Minicraft Models Toys Experts
ray gallant
Are you a Minicraft Models Toy Expert? Answer questions, earn points and help others
