Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Need to know where wire that comes from controls on hot tub connect to pump at?
    President:
  • Aqua Flo Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Assuming you have a standard white, black red, green cordset, green to ground, white to common, red to high and black to low. If the speeds are ‘reversed’, interchange the red and black leads. You likely have an AOSmith motor which will be labeled 1, 2, ¾ on the terminal board. 1 is common, 2 is high and ¾ is low.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 15, 2010
I replaced my circulation pump on my hot tub and now all I get is a clicking sound when I power up the tub
It sounds like it was wired incorrectly, check your connection coming into the pump. It also may have a selection for 110 or 220 power that has to be ajusted.
Mar 11, 2014 | Pool & Spa
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Trying to connect a Tork A530 MW timer to a spa tub pump
  1. The white wire (neutral) in your feed cable from the electric panel should be connected to the white (neutral) wire going to the pump.
  2. This switch is wired in 'series' in the hot (black wire) leg. That means one black timer wire connects to the black wire in the feed cable from your electric panel and the other black timer wire connects to the black wire that goes out to the pump.
  3. I the diagram the switch is your timer and the light bulb is the pump. The switch is in series with the pump.
Nov 13, 2013 | Tork Spring Wound Interval Timer
Bought hot tub used need to know what size supply wiring and breaker I need
Check your heater/pump/lights/accessories. These should all have electrical ratings. Your supply wire should be large enough to carry the combined amperage of everything running together. I personally would separate each system in the breaker box, 1 for pump, 1 for heater, 1 for accessories.
Apr 09, 2013 | Pool & Spa
Wiring diagram for ff32atc control box
If your hot tub has been submersed by water then you are going to need all new controls for it.
NEW control box with a new topside, New motor and whatever else is electrical under the skirt of the tub.
Start your search by getting the brand name and model number off each item.
Rod
US Parts Center
888-521-6183
Mar 19, 2013 | Pool & Spa
Hot tub breaker not tripped but nothing works
Sounds like your controller has sustained damage. You need to have a professional inspect it to determine what has gone wrong.
Apr 14, 2010 | Pool & Spa
I have a 2000 Sovereign Hot Spring hot tub that quite heating, I checked filters they are ok, I have no air lock, The jets and light work fine. Inside the control box on the circuit board all 3 led lights...
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
Mar 31, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
WE DRAINED AND FILLED OUR HOT TUB AND NOW THE POWER TO THE TUB WON'T COME ON. ANY IDEAS?
The fix was a replacement timer/control piece which is connected by two wires to the pump behind the tub (access wall) and plugged into the outlet;
Nov 22, 2009 | FixYa Service
Qca hot tub pump not turning on
if the pump is a 240volt maybe a blown fuse. If you turn the tub on and hear the pump make a low hum it prob. is a bad pump remove and replace. you really need a multimeter to check to c if your getting power to pump. if you send me a email i could walk you through testing the pump and control box.
Jul 05, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
239 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
