Question about Coleman 10' X 10' Sundome Tent 9160K101
Outdoor umbrella need to rethread rope on crank mechanism to open
Patio table umbrella rope inside pole which is supposed to be wound around crank mechanism has come undone and cannot rethread it to enable crank to open umbrella.
On my patio umbrella,, when i crank to fold down,,,it starts closing,then at a certain point,,about half way,,,it starts opening again,,, please help
Not a complete answer but it might help to know the following.
On my umbrella the rope is wound around a pulley such that if you wind it down and keep turning the same way the rope will start to wind back up in the other direction on the pulley and the umbrella will lift again. Maybe the rope on yours is stuck in the middle somehow and when it catches the rope starts winding up in the other direction.
Oct 02, 2017 | Baby Gear
How to Replace Cord In Patio Umbrellas
i would think you can unscrew the crank assy. attach and feed new rope from the top down the tube and attach it to the crank assy. then just put it back in and screw it down. use a good cord maybe even parachute cord from maybe home depot or lowes
Sep 12, 2017 | Heating & Cooling
How can I fix the rip on my patio umbrella
why bother, most of them are made in China and like most stuff we are a throw away society, it will cost you plenty for glue and material if you still chose to fix it, The most I get frmo umbrellas int eh desert sun is barely a year.
May 31, 2015 | SONOMA outdoors Crank And Tilt Solar Led...
Our string broke on our patio umbrella. is it fixable?
It absolutely is fixable, type restring patio umbrella into your search engine and look at several of the YouTube videos detailing how it can be fixed. The hardest part may be to source the string, why not contact the manufactures and ask if they can supply it. As an additional note you need to make sure all the moving bits work properly and are lubricated not sticking, the string may have broken due to excessive force being needed because all was not as friction free as it should be. http://wwww.dayva.com/contact
Jun 17, 2014 | Dayva 6 Ft Huntington Series Patio...
The plastc crank insets for the crank handle is striped as it is plastic. Where do I get another one?
The same thing happened with ours within the first year. Were you able to find a part to fix it?
Jun 01, 2014 | SONOMA outdoors Lighted Patio Umbrella
I brough an umbrella stand that is suppose to be used with a table. How do I turn the base into free staning.
The table stand will have some or all of these four deficiencies: 1. Too small diameter 2. Too light-weight 3. Too short and weak of a neck to support the pole 4. No mechanism to secure the pole to the base
So any breeze would tip it over, break off the neck, or lift it right out of the base. Without seeing the base you have I can't be certain, but your likelihood of success is pretty slim.
Jun 28, 2010 | Garden
Patio umbrella tilt locking hinge broke
Need a fix for my patio umbrella the wind snpped the push button tilt mechanism.
Mar 31, 2009 | Garden
Hampton bay patio umbrella bent pole
Yes there is, I found it on amazon, take a look here: Amazon com umbrella pole replacement . I hope this was helpful. cheers
Mar 29, 2008 | Televison & Video
Coleman 10' X 10' Sundome Tent 9160K101 Logo
169 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
