I have a houseful of I pod touches, and 3 different docking audio devices in the house. (2 sony, 1 ihome)My sony bookshelf system has developed an issue where it charges but will no longer play sound from the ipods nor control the ipod with it's controls when docked. My wife discovered she could apply forward pressure the the ipod and cause the connection to work, but this makes me nervous and obviously doesn't help much. What can I do to solve this?
  • dave_shrum May 15, 2010
    I have a houseful of I pod touches, and 3 different docking audio devices in the house. (2 sony, 1 ihome)My sony bookshelf system has developed an issue where it charges but will no longer play sound from the ipods nor control the ipod with it's controls when docked. My wife discovered she could More
    Please accept or reject most recent solution
    Solution #1
    posted on May 15, 2010
    kid_ant
    Rank: Guru
    Rating: 96.62% , 327 votes
    First, check to see if the iPod dock's connection is not loose at the back of your audio system.
    If everything is tightly connected, unplug the power chord for a couple of minutes (around 5 to 10 minutes).
    May 15, 2010 - It's built in, so there is no connection wire, etc. to check. I will try the unplugging idea and see if that yields a result.
    May 15, 2010 - Didn't work unplugging the unit....any other thoughts? It's obviously something internal to the connector on the docking unit itself.
You will need to clean the contacts on your Sony bookshelf (where the ipod docks) with a QTIP and some rubbing alcohol. Next, look at your ipod touch and see that the contacts are clean. If the contact board is bent to far back then you will need to open it up and adjust it so it will meet flush with your ipod.
Posted on May 15, 2010
    Tried the alcohol but unfortunately didn't help. I don't think there is a problem with the contact board on my ipod being bent as I have 4 touches in the house and they all work fine with the other 2 devices in the house, but all of the 4 have the issue I described with the sony bookshelf unit. Do you know if it's possible to adjust the angle of contact on the docking unit itself or to replace the part on the docking unit?
  • 881 Answers
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
Tip
How to connect an my iPod Nano 3rd Generation to an iHome
<p>Your iPod nano to a device like the iHome to boost output audio or video to a TV in your memory. The iHome also charge your phone as it is docked. You need to take steps to ensure that your iPod will be able to successfully dock the iHome. Once your iPod is well prepared, so you get the most out of your drive for iHome. <br /> <p><br /> <p>1. Connect your iPod to your computer and launch iTunes. <br /> <p><br /> <p>2. Click "Help" from within iTunes, click "Check for Updates". <br /> <p><br /> <p>3. Select "Yes" when asked if you want to download and install updates. If no updates are available, disconnect the iPod. <br /> <p><br /> <p>4. IHome Connect your unit to an AC outlet. <br /> <p><br /> <p>5. Remove the protective layer of your iPod Nano, if applicable. <br /> <p><br /> <p>6. Let the iPod Nano in the dock with the front facing you. You will feel it snap into place. <br />
on Jul 21, 2011 | Computers & Internet
I got my iHome a little less then 2 months ago, I never had a problem with it and it worked fine. Just this morning I charged my iPod Touch with it and it worked fine, then I tried it again later and it...
If it is only two months old, put it in for repair under warranty.
The fact that two devices don't charge indicate it is probably faulty.
Before you do, first check all the obvious things.
Check the docking cradle is clear of fluff, paper or cat hair.
Check that any switches are in the on position.
Check that all cables are plugged in.
You may not have changed anything, but someone else may have.
Feb 12, 2011 | iHome Portable Speaker System for...
I bought an ihome p90 it wont play my ipod touch
It is very possible that the ihome p90 is not compatible with the ipod touch. unfortunately for us, the different generations of ipods are not all the same and not all work on different docks. To verify that your itouch is not the problem, borrow someone elses and try to see if that will play. I'm willing to bet that its just the dock that is not compatible with that specific version of the itouch.
Good luck
Jan 08, 2011 | Audio Players & Recorders
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
New ipod, old ihome. "device not supported" Any way around?
I'm sorry but no. the ihome is only for the 1st generation, so if you want to use it with your new ipod, you need to buy another one that supports second generation. this is a bummer, but its how they make their money.
Jul 28, 2009 | Apple iPod touch Second Gen (8 GB,...
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
I-pod shuffle copatibility with car stereo
No, The iPod Shuffle only transmits Audio, not data.
May 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
55 people viewed this question
 Grubhead
Grubhead
