Question about Mastercool Portable Air Conditioner
Master cool mmb12d owners manual for installing pads
2 Suggested Answers
  • 4736 Answers
SOURCE: Need a water pump for
Here's a link to where you might find the pump you need. http://www.indoorcomfortsupply.com/cgi-bin/commerce.exe?search=action&category=PUM0
Hope this helped you.
Posted on Jun 24, 2011
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
Free download norcold n611 rv refrigerator manual
DOWNLOADS
Parts List-06-08-12Reference6/13/2012669.77 Owner's Instructions - Cooling Unit InstructionsTechnical7/12/200728.17 Installation Manual - 3/23/06 - 2/19/07User Manual7/12/2007872.04 Installation Manual - 8/2/04 - 3/23/06User Manual7/12/2007791.81 Installation Manual - CurrentUser Manual6/16/20091,239.84 Installation Manual - Through 8/2/04User Manual7/12/2007508.79 Owner's Manual - 3/23/06 - 2/19/07User Manual7/12/2007370.63 Owner's Manual - CurrentUser Manual1/20/2010630.82 Owner's Manual - Through 3/23/06User Manual7/12/2007394.09
I believe you can find the fault codes above. Here is a link to the Norcold N611 Information and Contact Page
Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
How do i change my brake pads on my honda accord ex 1994
Fig. Fig. 1: The pads can be viewed through the inspection hole
Remember that you are looking at the profile of the pad, not the whole thing. Brake pads can wear on a taper which may not be visible through the window. It is also not possible to check the contact surface for cracking or scoring from this position. This quick check can be helpful only as a reference; detailed inspection requires pad removal.
Fig. Fig. 2: It is best to remove the pads to check for taper
REMOVAL & INSTALLATION
See Figures 3, 4, 5, 6 and 7
CAUTION If the car was recently driven, the brake components will be hot. Wear protective gloves.
  1. .
  2. Loosen the lug nuts, then raise and support the vehicle safely.
  3. Remove the wheel.
  4. As required, separate the brake hose clamp from the strut or knuckle by removing the retaining bolts.
  5. Remove the lower caliper retaining bolt and pivot the caliper upward, off the pads.
Fig. Fig. 3: Remove the lower caliper retaining bolt ...
Fig. Fig. 4: ... and pivot the caliper upward, off the pads
  1. Remove the pads, shims and pad retainers.
Fig. Fig. 5: Remove the pads, shims ...
Fig. Fig. 6: ... and pad retainers
To install:
Fig. Fig. 7: Front brake pad components
  1. Clean the caliper thoroughly; remove any rust from the lip of the disc or rotor. Check the brake rotor for grooves or cracks. If any heavy scoring is present, the rotor must be replaced.
  2. Install the pad retainers. Apply a brake-quiet compound (available at most auto parts strores) to both surfaces of the shims and the back of the disc brake pads. Do not get the compound on the braking surface of the pad.
  3. Install the pads and shims. The pad with the wear indicator goes in the inboard position.
  4. Push in the caliper piston so the caliper will fit over the pads. This is most easily accomplished with a large C-clamp. As the piston is forced back into the caliper, fluid will be forced back into the master cylinder reservoir. It may be necessary to siphon some fluid out to prevent overflowing.
  5. Pivot the caliper down into position and tighten the mounting bolt to 33 ft. lbs. (45 Nm).
  6. Connect the brake hose to the strut or knuckle, if removed. Install the wheel and lower the vehicle to the ground.
  7. Check the master cylinder and add fluid as required, then install the master cylinder cover.
  8. Depress the brake pedal several times and make sure that the movement feels normal. The first brake pedal application may result in a very "long" pedal due to the pistons being retracted. Always make several brake applications before starting the vehicle. Bleeding is not usually necessary after pad replacement.
Braking should be moderate for the first 5 miles or so until the new pads seat correctly. The new pads will bed best if put through several moderate heating and cooling cycles. Avoid hard braking until the brakes have experienced several long, slow stops with time to cool in between. Taking the time to properly bed the brakes will yield quieter operation, more efficient stopping and contribute to extended brake life.
  1. If equipped, enable the SRS system and connect the negative battery cable.
Jan 19, 2011 | 1994 Honda Accord
How do you replace the front and rear brakes in a 2003 pontiac Grand Prix
Removal & Installation Front To Remove:
  1. Inspect the fluid level in the master cylinder reservoir. Remove fluid from the reservoir until the level is lower then half way between the MAX and MIN levels.
  2. Remove the tire and wheel assembly.
  3. Install 2 wheel nuts to secure the rotor on the hub.
  4. Remove the bottom brake caliper pin bolt.
  5. Pivot the brake caliper body upward and secure out of the way. Do NOT disconnect the hydraulic brake flexible hose from the caliper.
  6. Compress the piston back into the bore using a C-clamp. Figure of brake assembly with caliper raised showing brake pads in mounting bracket gmpc_l4.gif
  7. Remove the inboard and outboard brake pads from the brake caliper bracket.
To Install:
  1. Install the brake pad retainers and both brake pads into the caliper bracket.
  2. Pivot the brake caliper down over the brake pads and into the brake caliper bracket. Insert the lower brake caliper pin bolt and torque bolt to 70 ft-lb. (95 Nm).
  3. Reinstall the tire and wheel assembly.
  4. Lower the vehicle.
  5. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  6. Check the master cylinder level and add fluid as necessary.
Rear To Remove:
  4. Remove the upper caliper mounting bolt.
  5. Pivot the caliper down to access the pads.
  6. Remove the inboard and outboard pads from the caliper bracket.
  7. Remove the brake pad clips from the caliper bracket.
  8. Compress the piston back into the bore using a C-clamp and the old inner pad.
To Install:
  1. Install new brake clips in the caliper bracket.
  2. Install the inboard and outboard pads in the caliper bracket.
  3. Pivot the caliper up over the pads.
  4. Reinstall the upper mounting bolt and tighten to 32 ft. lbs. (44 Nm).
  5. Remove the 2 wheel nuts securing the rotor.
  6. Reinstall the tire and wheel assembly.
  7. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  8. Check the master cylinder level and add fluid as necessary.
Aug 26, 2010 | 2003 Pontiac Grand Prix
Self cleaning instructions
If the model number is correct, the self-cleaning instructions are as follows:
1. Make sure oven door is closed and press "CLEAN".
2. "REMOVE RACKS" should be displayed. Remove all oven racks to avoid damaging them.
3. Select "CONTINUE" using the Quickset pads on either side of the control panel.
4. Set LIGHT soil level by entering "200" using the number pads for 2 hours cleaning. Select MEDIUM for 3 hours. Select HEAVY for 4 hours.
5. "CLEAN", "TIME", "LOCKED" and the cleaning time countdown will be displayed while the oven is cleaning.
6. "OVEN COOLING" will appear when the cleaning time is complete, but the oven door will remain locked until it is safe to open. (approx. one hour after cleaning cycle ends).
These instructions are almost verbatim on page 23 of your owner/operator's manual. If you no longer have a manual, you can go to managemylife.com and enter your model number under the "Manuals" link. Your owner and installation manuals are listed in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Feb 20, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Change Front Brake pads
(10) Install master cylinder fluid reservoir cap.
Hope this helps...I know it's extremely difficult to find manuals for these cars. These instructions are straight out of the factory service manual.
Nov 22, 2009 | 2006 Chrysler Pacifica
Master cool thermostat timer hours 7 and 8 are
I have the same problem and hope someone has a solution
Jul 04, 2009 | Heating & Cooling
Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Mastercool  Portable Air Conditioner Logo
336 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
