Question about Amana 22 cu.ft. Side-By-Side Cabinet Depth Refrigerator, ACD2238HTS
Freezer only goes down to 20 degrees
I've checked the thermostat and checked the deforst control all appear to work but temperature won't go down past 20 degrees in the freeser
5 Suggested Answers
  • 1550 Answers
SOURCE: No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Posted on Sep 30, 2008
  • 415 Answers
SOURCE: not cooling enough
sometimes you do everything proper and when repair is done another failure occurs because of long run times because not defrstng . the orginal freon charge may have been alittle on the low side and weakened the compressor what you can do is tap the seal system and add 1/2 of the orginal charge listed below the model # should be 134a this will often work for quite some time and remove the panel off the evap in the frzr and observe the frosting on the coils it should be uniform on the evap with no places getting missed if you can not tell temporily move frzr item and unplug to allow frost to thaw then plug back in and open door allow to run 30 min then look at again if only on part of the evap perhaps top or the lower then you know the orginal charge was low then add freon it sound you are very mech person and possible you may need to add the orginal charge to unit (the compressor has taken heat and it has weakened it)
Posted on Aug 20, 2009
heatman101
  • 43501 Answers
SOURCE: Bottom freezer (10 yrs. old)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 12, 2011
  • 139 Answers
SOURCE: Wide variation in temperature in
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
Posted on Aug 17, 2011
The temperature controls on fridge and freezer just keeps on running. Freezer goes to minus 20 degrees F
Most likely it's the thermostat. Not necessarily the controls but the thermocouple itself.
Here are 2 videos, the first one is about the opposite problem where the system won't cool. The "wire" sticking out of the thermostat he's removed is the thermocouple, sometimes you can replace that by itself.
The second covers a more sophisticated system and both possible failures.
Nov 03, 2016 | Refrigerators
Amana bottom freezer temp 16 below. Turn temp down a little temp goes to 20 above
With that kind of spuratic actions I would strongly lean toward that the temperature control, also know as the cold control , is probably malfucntioning. Before I can 100% call that fact I would need more inforamtion, model number the most important. Also, a description of how the machine looks on the inside, like frost on the wall, ice, etc.
Apr 29, 2012 | Refrigerators
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
GE PROFILE REFRIGERATOR SIDE BY SIDE IS NOT COOLING DOWN TO THE PROPER TEMPERATURE FREEZER REMAINS AT 20 DEGREES AND REFRIGERATOR AT 47
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer will not cool down to 0 degrees F (48 degrees is the coolest). Fan is working, cooling condenser is clean and it appears the compressor is operating.....
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Oct 01, 2009 | Refrigerators
Refrigerator not cooling but the freezer ok
Sounds like the thermostat or control mechanism is broken in the fridge compartment. You willneed to call a service engineer to fix it or risk getting ill.
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Amana 22 cu.ft. Side-By-Side Cabinet Depth Refrigerator, ACD2238HTS Logo
240 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
