Question about Moen 7910 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome...
I am leaking at the base of the spout. if you put any kind of pressure on it to move it from side to side it leaks. this is a two handle kitchen meon faucet
  • 349 Answers
At the base of the spout it should have an o ring on the spout does it have a nut or cap on the spout that will unscrew to gain access to it. turn water off first.
If it is loose you could try tighting it , but most of the time it would be th e or ring.
Posted on May 18, 2010
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
Jul 15, 2011 | American Standard 4205.001.021 Reliant+...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Moen 7910 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome... Logo
305 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
