Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
The soap I have been using for a long time is not dissolving.
I have run different cycles and none dissolve the soap.
  • Bosch Master
  • 43,501 Answers
Detergent is still full after 5 washings. I ran it through several cycles and purchased powder to run it and it still will not work
What? The soap lid won't open, or the soap won't dissolve? If the lid is opening, but the soap won't dissolve, then you're not getting proper water flow. Check your wash arms for clogged holes. The other thing to check is the sump area for a clogged food trap or clogged or broken chopper. You might be able to find a video on YouTube that shows you how to do this, otherwise, you should call a professional dishwasher repairman.
Sep 25, 2014 | Kenmore Dishwashers
Soap leaves behind after wash cycle
Could be using too much soap, soap that's too old will clump and not dissolve completely. If your soap is clumpy and very dry, dissolve it completely with boiling water in a pan, then put it in the unit.
Jun 15, 2014 | Maytag Neptune FAV6800AW Top Load Washer
The soap doesn't dissolve
your using to much soap . pour vinegar about a half cup into the bottom of the washer before you start, do this about 3 washes then should be okay,
Sep 09, 2012 | Magic Chef 5-Cycle Dishwasher
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Using powder 1/2 recommend amount. there is a continual build up of powder in the dispensing cavity behind drawer. how do I prevent this am having to clean with toothbrush daily
Hi
When you start a cycle, does the machine take a long time for it to fill up with water.
If so, you have a faulty inlet valve. There is a rubber diaphram inside the valve which tends to tear over time.When this happens the water just trickles in. Therefore the soap/powder is not dissolved into the tub thouroughly.
Some powders also dissolve less than others, and using the machine on hot water cycle helps to dissolve the soap faster.
Regards
Ash
Nov 12, 2009 | LG WM-2277HW Front Load Washer
The soap packet doesn't dissolve, it remains intact at the bottom of the machine at the end of the cycle.
don,t use those packets stay with powder or liquid dishwasher soap. the packets need a lot of heat to dissolve,.
May 29, 2009 | GE Nautilus 24" Built-in Dishwasher
My soap won't dissolve during the cycle.
You are not getting enough water or you are losing the water during wash cycle. Is you dishwasher new or older? How is it plumbed in? If it is plumbed through the floor you will have to put and air gap in to keep the water in it. All tall tub dishwasher have to be plumbed properly.
Jan 05, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Tablets not dissolving
Sounds like whatever soap you are using is just too much soap your dishwsher can handle. The soap "packs" are usulally an overload of soap for most dishwashers. Just a few teaspoons of regular name brand soap sometimes will cure lots of dishwsher ills!!!
Apr 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
131 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
