Question about Kenmore Dryers
What is fault code F- on a Kenmore model 110.8656 clothes dryer. The dryer stops and all the lights on the control knob start blinking.
Jimster
  • 240 Answers
SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
BerkelUSA
  • 24 Answers
SOURCE: HE4 Kenmore Elite Dryer error code 4e
If you have ever removed the lint filter area completely via the screws that hold the plastics in so you could clean it then remove it again and insure that you plugged in the two wires that go to the strip sensor.. (moisture sensor)
Posted on May 17, 2008
muttandjeff
  • 359 Answers
SOURCE: kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Posted on Dec 23, 2008
  • 97 Answers
SOURCE: kenmore electric dryer (model # 110 60202990)
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Mai
Dec 16, 2013 | Kenmore 800 7982 Dryer
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Feb 07, 2007 | Kenmore 62622 Electric Dryer
Dryers Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
