Question about Maytag Neptune MDG5500AW Gas Dryer
Neptune Drying Center MCGAWW (No Heat)
Can't figure out why there in no heat on this dryer...just stopped working. Everything seems to be working fine, but not heat. This has auto ignition, so I can;t check/light the pilot...HELP!
  • 725 Answers
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Posted on Apr 05, 2008
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
The lower portion of my Neptune Drying Center does not get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 31, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Dryer is gradually stopped heating and drying
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
=00
Jan 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Our Maytag Neptune gas dryer runs but no heating of the air either on sensor dry mode or timed drying we have cleaned out the lint tripa etc and it does not seem to change anything
heatman101
Nov 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Not heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
heatman101
Apr 05, 2010 | Maytag Neptune MDE6800A Electric Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Low heat, not drying
There´s a sensor inside that controls the temperature in order to prevent overheating.
Mostly they work with resistance. Oxydation can influence the resistance value, as like as some fluff.
Second option: you have perhaps not only one heating coil, perhaps one is not working.
Sep 19, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune Drying Center MCE8000AYW
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
379 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
