Question about Brother DCP 115C All-In-One InkJet Printer
Brother MFC-820CW Fehler: Drucken Ger├Ątefehler 4F Habe alle Patronen ausgewechselt. Problem immer noch. Scanner funktioniert, Drucken kann ich nicht. Patronen reinigen ebenfals nicht!
4 Suggested Answers
  • 100 Answers
SOURCE: Fehler Tintensystem: Fehl. 0xc19a0035 Sind alles orginal
This same error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Posted on Mar 28, 2011
pineworks
  • 4041 Answers
SOURCE: Gerätefehler 4F
Hi thereGood Luck hope work
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
puertobori
  • 7733 Answers
SOURCE: ich kann meinen drucker kodak
go to Kodak Help Center
Posted on Oct 28, 2010
Cyberhome SP05A speaker system
Hallo ich hoffe ich bekomme eine Antwort. SO ich habe die CyberHome speaker system 5.1 ch und habe alles angeschlossen, nur mir fehlt das DC 12v 50w kabel von der Box wo man den Bass/Volumen/EIN und Aus regeln kann und nu meine frage BRAUCH ich das und wenn ja wo kann ich sowas nachkaufen? ich habe schon gegoogelt (dc 12v 50w) und habe nichs gefunden. jetzt habe ich zuhause noch 2x DC Stecker gefunden DC 12v 700mA und DC 12v 1A aber die passen nicht rein. und nu will ich nichs kaufen wenn ich nicht genau wei? ob es passt. Linkt zu kaufseiten w?hren auch gut. ^^
danke schonmal im Vorraus.
mfg ICH :P
Sep 02, 2013 | Cyberhome Area SP05A Speaker
Für die Übertragung eines Filmes von dem Camcorder Panasonic NV-GS17G brauche ich einen Firewireanschluss am Notebook Aspire 7736. Welches Gerät eignet sich für einen Einbau? Mit...
Hallo Horst,
Ich habe die Spezifikationen f?r beide Ger?te nachgeschaut und sehe, dass beide einen USB 2.0 Anschluss haben.
Damit sollte eine ?bertragung doch m?glich sein, oder ?bersehe ich da etwas?
Selbst wenn Du einen USB->Firewire Adapter installieren w?rdest, w?re die ?bertragungsgeschwindigkeit durch das langsamste Glied in der Kette bestimmt.
USB 2.0: 480 Mbps
Firewire 400: 400 Mbps
Firewire 800: 800 Mbps
Einen Firewireanschluss in ein Laptop zu installieren is nahezu unm?glich, weil kein Platz f?r Erweiterungen vorgesehen ist.
Es gibt aber externe Alternativen (siehe z.B. hier).
Pass auf, dass Du eine Firewire800 card kaufst - 400 w?re langsamer als der eingebaute USB port!
Wenn Du noch weitere Fragen hast, schreibe einfach einen Kommentar - vielleicht kann ich helfen.
Viel Gl?ck!
Sep 19, 2010 | Acer Aspire M3201 Phenom X3 8650 PC...
Habe einen Acer Veriton 7600 G der sich einer
Hallo,
Also wäre nett wenn du ihn saubermachen würdest. Viel zu viel staub. Es kann aber auch sein das sich dein Ventilator nicht mehr dreht, weil er total verstaubt ist oder ausgebrannt. Um dies zu testen, bitte den PC ausschaulten, öffnen dann den Ventilator mit dem finger drehen und sehen ob dies einfach geht. Wenn er sich nur sehr schwer dreht oder garnicht, dann muss er ausgewechselt werden.
Abschalten, ist einfach weil der Ventilator den CPU nicht genügent oder garnicht abkühlen kann.
Apr 18, 2010 | Acer Veriton 7600G PC Desktop
Hallo. Seit einigen Tagen habe ich in der Früh nach dem Einschalten des Acer Aspire 5630 eine falsche Systemzeit. Woran kann das liegen? Wie kann ich diesen Fehler beheben? Danke!!
Sie können dieses durch das rechte Klicken auf Taktgeber Ikone, im unteren rechten Werkzeugstab regeln. Auserwählt justieren Sie Datum und Zeit, justieren ihn hier. Sobald getan ihm mit einem Zeitbediener aktualisiert. Erinnern Sie sich an Tageslichteinsparung.
Mar 30, 2010 | Acer Aspire 5630 Notebook
Sicherheitskopie von Corel Draw 11 (gekauft 2002) hat ein Serien-Nr. notiert, die heute offensichtlich nicht mehr funktioniert, es sei ich habe eine Fehler auf der CD gemacht. Brauche jetzt temporär...
I install Corel Draw 7, a package I had and what helps me to work on cdr datas I produced on my old system, some years ago.
Thanks, and I wish you
Happy New Year!
Carl Pohler
Jan 03, 2010 | CorelDRAW® Graphics Suite X3 Upgrade...
What does error 6000 mean on Canon MP630? It keeps telling me it's printing then the paper runs through without anything being printed on it. Thanks for any help.
Error 6000; Fehler 6000.
"Error 6000 is a mechanical problem of paper-input." (Hotline)
Remove paper-tray and check the rail inside as deep as you can see. (look for stuff!) Then try again. All other atempts are hopeless and send it to service.
Ich habe die abstrusesten Antworten im Net gelesen:
z.B. "Fehler 6000 bedeutet, dass die maximale Anzahl der Drucke erreicht ist und das Gerät wegzuschmeißen ist!"
Ich habe beim Service angerufen. Die meinten, es liegt ein mechanischer Fehler im internen Papiereinzug vor.
Das Gerät muss eingeschickt werden. Reparatur von eigener Hand aus nicht möglich.
Papiereinzug? Ich habe dann die Schublade einmal ganz rausgezogen und nach Störteilen auf der Schubladenbahn gesucht.(und gefunden!) Tatsächlich ging die Schublade danach sehr leicht wieder rein und der Drucker lief wieder. Alle anderen Recherchen sind m.E. vertane Zeitverschwendung!
Nov 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hallo, meine Camera wie oben funktioniert nur noch wenn keine Speicher- karte im Gerät ist. Mit Speicherkarte ist kein Strom vorhanden. Wo ist hier das Problem. Habe kein Geld für teure...
Ich bitte um Entschuldigung, aber ich bin mit Google übersetzer. Bitte schauen Sie in Ihrer Kamera CF-Karten-Slot. Ich vermute, dass Sie eine gebogene Nadel in es haben kann. Wenn ja, entfernen Sie die Batterien und Karte. Verwenden Sie einen kleinen / dünnen Juwelier flachen Schraubenzieher, bis die Nadel verbiegen wieder so nah wie möglich. Eine preiswerte Juwelier Schraubenzieher funktioniert problemlos. Ein weiteres Tool, benutze ich manchmal ist ein steifer Draht mit einem gebogenen Haken am Ende. Dies trägt dazu bei sehr flachen Pins erhalten begonnen. Nehmen Sie sich Zeit und verbrauchen viel Geduld (machen Sie eine Pause dazwischen, wenn nötig). Macht einfach weiter es nach oben und gerader einer "kleinen Menge zu einer Zeit". Was immer Sie tun, versuchen Sie nicht, um es mit einem Tastendruck entspannen, werden Sie nicht in der Lage, es zu tun.
Es muss nicht perfekt sein, nur so nah wie man es bekommen kann. Wenn es das Beste, was Sie es bekommen können, nehmen Sie Ihre Flash-Karte und "langsam" einfügen. Die Karte selbst ist fein-align des Stiftes. Entfernen Sie die Karte, und stellen Sie sicher, dass die PIN noch gerade ist. Wenn ja, setzen Sie die Karte und versuchen, die Kamera.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
Gerätefehler 4F
May 18, 2009 | Brother DCP 115C All-In-One InkJet Printer
Fritz!BOX fon WLAN 7170
DHCP und FritzBox gibt öfters Probleme.
Ich würde eher meine Drucker auf DHCP umstellen als den Rest der PCs und die Fritzbox.
Bei HP - Druckern kann man das via InternetExplorer ändern.
DHCP vergibt zwar die IP´s automatisch, aber nicht dauernd neu.
Erst wenn die maximale Anzahl an Geräten erreicht ist oder ein komplettes Reset gemacht wird.
In meinem Netzwerk laufen 5 Rechner und 3 Drucker, verbunden über einen SMC - Switch, alles über DHCP. Geht problemlos.
übrigens: das ist ein englischsprachiges Forum, da kann eine Frage auf Deutsch länger bis zur Beantwortung brauchen :)
Aug 18, 2008 | AVM Computers & Internet
Brother DCP 115C All-In-One InkJet Printer Logo
350 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
