Question about Intel Motherboard
Booting problem my mother board is D945gcnl my problem is switch on a computer iam not seen any display. Only hdd led is blinking and key board nums lock is working. I am expect your soluation. Thank you, frank
  • 66 Answers
Either the internal video on the motherboard has failed or the video card has failed. look at the back of the unit if the video port is twords the bottom then it is a removable card if it is at the top then it is integrated and you will have to dish out money for a replacement mother board
Posted on May 15, 2010
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
Hai sir iam using in intel d945gcnl desktop is propleam (a bootable device has not been detected)wihch propleam in intel board
Do you have multiple hard drives in your system. In the BIOS select the first boot device and select the 2nd HDD as first boot device.
to get into the bios press del and then use cursor keys to highlight boot tab and then select first boot device as HDD. Use the hard drive boot priority menu to select appropriate HDD as first device to boot.This option is only valid if you have two or more hdd's else your OS is corrupt and you will have to reinstall windows. Even check if all the cables to your HDD are tight, you will have to open up the system , if the system was moved around the cables might have become loose and just have to pushed in well.
Mar 03, 2011 | Intel D945GCNL Motherboard
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
Blink: 3 - Caps Lock/Num Lock
Memory
Blink: 4 - Caps Lock/Num Lock
Graphics
Blink: 5 - Caps Lock/Num Lock
System board
Blink: 6 - Caps Lock/Num Lock
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
System not booting
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-23
Feb 03, 2009 | Mercury P4VM800M7 Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Mother board problem
need more info. ? have you tred other drivs. ?
Jan 07, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Intel Motherboard Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
