Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Tv still wont provide a pic after lamp replacement
  • 273 Answers
There are several things that can cause this problem with this unit first off look at the back there is a vent opening when turning the set on there is a little box fan that needs to be running if its sluggish or stalled this can cause the unit not to initialize and operate
secondly there are caps in the DM moduel and power supply that can cause this sysmptom as well
and there is a possability of a color wheel or a ballast board also causing the problem
start with the fan first
Posted on May 15, 2010
    President:
  • Mitsubishi Master
  • 1,619 Answers
Cooling fans cleaned out? including projector assembly? Next thing to check after that are the capacitor on the power supply and other boards.
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Hello, my westinghouse tv has sound but no picture. when the tv is turned on, the pic comes on for a second then goes away. tv is 3 yrs old
You have 1 or more bad lamps in your display panel. You can get replacement lamps, but there is a lot going on to change them. If you are not experienced in electronics, I would suggest you let a service provider fix it, or invest in a new set.
Apr 04, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Just replaced bulb. Solid yellow led with no pic
hello make sure the lamp is fitted securely and the lamp cover is fitted securely aswell good luck
regards
shaun
May 21, 2010 | Toshiba 62HM196 62" SD Television
Sony rear projection standby light stays on color red, has no pic or sound ? help please.
Hi,it sounds like its time to replace the lamp,especially if tv is between 2-3 yrs .Any clicking noises? if you do it could be an issue with the board that powers the lamp it's called the ballast.Your lamp is made by Philips and it last 6000-8000 hrs ,make sure you get the original, generics dont provide same quality and life time is way shorter 4000 hrs 6 mths - 1 yr.Have a blessed life!
Nov 17, 2009 | Televison & Video
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Thanks.
Sep 22, 2009 | Sony Televison & Video
Samsung hlt5076 replace lamp still no pic lamp
If you have home insurance you can claim repairs under "Fusion" But the work has to be carried out by a licensed repairer who provides an account that clearly states that your unit suffered fusion. contact your insurance for a claim form and dont mention lightning
Parts and some labour are covered depending on the policy. Cheaper than doing a X Y board replacement yourself
Sep 05, 2009 | Televison & Video
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Lamp light no pic
yes yes yes.the lamp needs replacement. you are very correct.that is the indication of lasmp replacement which your tv is signalling.replace it quickly.
howto replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
No pic and shuts off
If the housing of the door comes open you will lose the sound and picture almost instantly. Have you replaced your lamp in this tv it sounds like the life on your lamp is coming to an end.
Oct 15, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
