Question about Dryers
My dryer stop working during drying. Belt is good.
  • Douglas Jensen May 15, 2010
    Need more specifics. Does the drum still tumble? Is it just humming? Is it just not getting heat?
    President:
  • 1,619 Answers
Replace heating element, or timer.
Posted on May 15, 2010
The dryer is on, but it will not start cycle. it stopped during drying
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 14, 2011 | Maytag Dryers
My Roper Dryer stops running during the drying cycle and takes a while to restart.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Oct 22, 2010 | Roper Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
Squeeking while dryer is drying
i would suggest calling the repiar. The longer you wait the more expensive this will be. One of two things is happening. One, bearing is going out, or most likely the belt is slipping on the drum and needs replacement. Good luck
Jul 09, 2009 | Dryers
My gas dryer stopped turning.
There are two options on why your dryer would stop turning.
1. Your dryer motor quite
2. the dryer belt either came off or broke.
you will need to take the dryer apart to see if the belt is broken. if not than it is your motor.
Please let me know if you need further assistance in this matter.
Thank you for choosing fixya. please do not forget to rate and comment about your experiance.
Jan 06, 2009 | Dryers
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
