Question about Dacor DMT2420 1200 Watts Microwave Oven
Sparks inside the microwave when power is turned on
When I turned on microwave with food in the unit it made crackling sounds and sparks on the inside of the microwave
  • Dacor Master
  • 9,085 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
The service manual is here.
Let me know if you need further help.
Posted on May 16, 2010
I have a magic chef over the stove microwave. It sparked underneath when I was using it, it does not turn or heat food nor does the light. But everything else works the keypad,the vent and the clock. It...
Sounds like the high-voltage magnetron (the heating unit) is not getting power. It could be as simple as a broken wire inside the unit (which would explain the spark) or a failed control board or high-voltage power supply (which also might let go with a spark).
Nov 06, 2014 | Microwave Ovens
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Not heating up food / drinks. makes a "crackling" sound when turned on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 05, 2010 | GE XL1800 1100 Watts Microwave Oven
My microwave oven heats, but makes strange crackling noises. Is it allright to keep using the unit?
No. Please have it checkd as it is dangerous to let the high voltage jump along side the magnetron. This will eventually result in the failure of the magnetron with a possible damage to the circuits.
So open and check if there is any foreign particles/insects struck within , Is the insulation damaged or remove the magnetron and clean the uni , clean the cabin specially if food haas accidently got spurted inside, dry the whole unit after cleaning before you fix back the magnetron.
The microwave must now work without crackling or else if the spark is seem near the magnetron , it must be replaced.
Hope this advice helps.
Aug 27, 2010 | Microwave Ovens
Microwave sparks inside oven in the area of the sealed compartment when it is started
If unit was run for long time with food on walls and not cleaned off, it is possible that the unit was burned in a spot where the food was and if there is metal frame under that part for the finish it will spark. Check closely for burns, if it is sparking due to that problem, junk it. It is a dangerous condition.
Jul 28, 2010 | Daewoo KOG-867T Microwave Oven
Crackling and popping sounds when you heat up food
thats normal water expanding and boiling off from the microwave boiling those tiny water pockets in food... sounds like popcorn sometimes.
Cover your food with a paper towel to avoid spatter on the ceiling of the microwave when this is happening.
Sep 12, 2009 | Sharp Microwave Ovens
No Power
It sounds like the fuse blew inside the unit. It can be replaced, but you need to find out what caused it. There are also thermal switches that will turn off the unit if it overheats. They are called "snap discs" because they have only one setting and will shut the unit down to protect it.
If you aren't familiar with this kind of work, do not attempt repairs. Take it to an appliance shop. It could be anything and a competent appliance shop will tell you if it's worth fixing.
Mar 22, 2009 | GE Microwave Ovens
GE microwave -crackles and sparks as if metal inside
The problem you are having is that the magnetron that does the heating is shorting out and it needs to be replaced before it damages the inside covering of the microwave. www.mwoparts.com is a good source for magnetrons or other similar sites. To replace is easy enough. Taking the cover off with the power off, you will find it behind and on the top right side of the control panel. It is held in place normally with just 4 screws and two wires with terminals attached to it. So removing and replacing is pretty straightforward. Just be sure all the power is off until you have everything back in place. Good luck.
Jan 23, 2009 | GE JES738 Microwave Oven
Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 02, 2008 | GE JEM25 Microwave Oven
No heat
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
381 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
