Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Chuck no tighting properly
Chuck not tighting properly
    Guru:
  • 351 Answers
Hi, In my experience when the keyless chuck is sticky , it is because of some substance or debris that has gotten into the mechanism. I have used air presure, and I have used copious amounts of WD 40 . to flush it out and lubricate the workings. Running it fully in both directions several times and flushing in between.
Or it has become damaged, and needs replacement ,..
Please Vote !!
Posted on May 15, 2010
The chuck on my Craftsman C3 drill won't stay tight
If you have a keyed chuck then yes as the jaws are not parallel any more from wear. If keyless then the thread inside the chuck cover is damaged and not tightening properly. So again yes a new chuck will be the answer.
Jul 29, 2013 | Craftsman Drills
Play in the sds chuck when a drill bit is inserted
This can be due poor chuck settings and could be that it is not tightening properly. You can oil or use some degreasing spray to unlock the jam or else the chuck could be defective.
Jun 27, 2012 | Washing Machines
Cant undo the chuck its really tight
Some chucks get dirt, grime, and other foreign stuff in them or they rust internally and get stuck. If it's too tight to get loose by hand you may have to use some WD40 or Liquid Wrench and a channel lock pliers or vice grips to hold it tight enough to get it loose. If that doesn't work you may be looking at cutting the chuck off and replacing it.
Feb 25, 2012 | Drills
How do you get the chuck off a dewalt 18v dcd970?
The chuck on your drill was made to be taken off with a special jig and holder that cost $175+. Depending on how tight and how much lok-tite the factory used some chucks can be removed without the jig. You need a hex shaft at least four inches long and 3/8" to 1/2" wide. Lock the hex-shaft tightly in the chuck, then put the shaft in a vice with the drill straight up and down. Using very firm and steady pressure, turn the drill using the handle for leverage until the chuck breaks free. Don't bounce the pressure or use an impact wrench as this is very ******* the transmission. When you put the new chuck on, use a few drops of lok-tite and put it on as tight as you can without breaking the case. Let the lok-tite set up for at least one day.
Jan 30, 2012 | Dewalt Drills
How do I change the drill bit?
you would hold chuck in a firm grasp as your hand around a pipe and hold tight,run drill in reverse and that should loosen the chuck and the bit. If its to tight for your hand get a pair of channel locks and hold chuck.
Jan 16, 2011 | Dewalt 18 Volt Compact Drill Kit
My 18v ryobi cordless drill does not hold a drill bit even tho i hold and tighten the chuck with my hand. It will hold for a wile but will eventually fall out. Thanks
Abrupt stops can loosen the ratcheting chucks. Before the invention of those chucks we had the ones that required a key. The proper way to tighten them is to alternate between all three position in order to "seat" the jaws on the bit evenly.That all but guaranteed it would not come loose I assume you have a ratcheting "one handed chuck". ther's only one way to tighten them and you don't get the same grabbing force. The only thing I can suggest is to try to eliminate abrupt stops or try cranking it tighter.
Jun 14, 2010 | Ryobi 18v Variable Speed Right Angle Drill...
There is a little metal plate that is sticking out at the back of the chuck and opening and closing of the chuck has become very hard. I cannot find a schematic for this drill. I took the screw chuck off...
Place tool lightly in vice, place any allen wrench , L shaped type , with long end out of chuck, small end in chuck. clamp chuck jaws tight around end of wrench. With pipe or hammer, tap end of wrench counter clock wise.
These chucks are tight.
Jul 08, 2009 | Panasonic 15.6v Ni-mh Cordless Drill -...
I have a very old 3/8'' elecric drill, I think it ia a Skil, The key chuck does not work properly and I want to replace it. How do I remove the old chuck?
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 12, 2009 | Drills
Chuck loosens
Chucks ARE meant to stay tight.
You also use drill to UNSCREW THINGS.
Nov 27, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
107 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
