Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Showing red tv shows red and pink and a bit darker not as bright. being told after reading and learning my self that is is the light engine. Is there a way a consumer can buy this projector as panasonic calls it? Panasonic will not sell to the average consumer and i am in the ackward position to pay some one to do what i can do....which makes the price up in the ( just buy another tv ...but make sure its not panasonic or hitachi. whats my options asside from never doing business to panasonic...again.
  • gotscrwd Apr 26, 2008
    I have gone thru 3 bulbs in 3 years WTF!! now I have pink i guess ghosts any solution?or do i drive this piece of sh&t over to panasonic and demand a new piece of sh&t?
  • 927 Answers
Good Day,
Three lamps, three years? You have a bad BALLAST. If your mech. you can do it yourself.
Good luck, big IRISH.
Posted on Aug 26, 2008
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
5100 HP Desktop printer--magenta ink comes out pink not red (right out of sealed package!)
magenta is just a fancy name for pink.... its usually a darker shade of pink not overly dark but not a bright pink that most associate with the color.
most hp printers use the ckmy color format as opposed to the rgb that most are used to. check your other ink levels to ensure that they are at least half full and when you print out a doc or pic requiring red, the other inks will assist in creating the proper shade
Mar 27, 2010 | HP Office Equipment & Supplies
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Engine Guage is showing Hot.
replace the temp sending unit on the engine first
Mar 11, 2009 | 2001 Pontiac Aztek
Pink and purple picture
Definitely bad optical block or "light engine".Common with Sony and EXPENSIVE.Some moodels were given an extended engine warranty because of problems ,but NOT this model.
Jan 10, 2009 | Sony KP-51HW40 51" Rear Projection...
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
Fushia Pink color on screen
It depends how many times the LED blinks. Tell me how many and I can read the description on the manual.
Jan 06, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
