Question about Cadco 10 in. KR-1 Electric Cooktop
My control element has burnt out.
I need replacement parts.
  • Cadco Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
How to replace an element
This could be a couple of issues, but unfortunately if it's your element, you would have to replace the entire element, not just the middle part. What's the rest of your model number? I can find a part number for you. (KECD806R****)
May 17, 2014 | KitchenAid KECD806R 30" Electric Cooktop,...
The front right burner isnt working
Most common fault is the hotplate element is faulty and requires replacement followed by a burnt off terminal at the hotplate terminal followed by a faulty control switch.
Feb 09, 2011 | Frigidaire 31 in. FEC30S7E Electric...
My electrician examined the cooker and found that the main element has a hole burnt in it.
This is a common problem and happens a lot. it is usually a flaw in the element that eventually burn a a hole right through it, and renders the element inoperative. They are relatively inexpensive to replace.
Aug 06, 2010 | Cooktops
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
One of the top elements does not heat up Can I just replace the element underneath. It is the one piece top.
The element is controlled by the switch, generally the element is bad, but it could also be the switch, or just a wire burnt off at a bad connection, which happens the least, but does happen.
After unplugging power, there are generally only two screws on the front corners on the underside to release top to lift up enough to test and service. There should be a schematic taped on the back or behind the control or alongside the broil drawer, it varies, to tell you which wires are for the element. Usually I make my own diagram of wires anyway to keep from mixing up.Suggest taking to a appliance store for testing if you do not have a meter, before replacing, also draw a line on the underside of the element to mark the location on the support bar to get it back in the correct spot.
good luck
Feb 19, 2010 | Cooktops
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Jul 13, 2008 | Jenn-Air JED7430 Electric Cooktop
Can't control temp of one element, is either high of off, nothing inbetween
- The infinite switch for the controller likely needs to be replaced, this part can be ordered from your nearest Jenn-air parts dealer
Mar 13, 2007 | Jenn-Air JED8230 Electric Cooktop
Cadco 10 in. KR-1 Electric Cooktop Logo
150 people viewed this question
Top Cadco Cooktops Experts
Paul Carew
Are you a Cadco Cooktop Expert? Answer questions, earn points and help others
