Question about Gateway FPD2275W LCD Monitor
Power is on but no display
Lights for the menu are working but only get intermitent display if fool with the buttons but only for a few seconds.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
How do I repair a Cabrio washing machine
Press the cancel button all indicator lights/LED should be off
Select any button except Power, Start,Pause/Cancel
e.g. select buttohttp://www.fixya.com/answer/answerpageslideview.aspx?thid=25219265&ctg=130n "Soil Level"
Press "Soil Level" button and hold for 3 seconds
Release "Soil Level" button wait for 3 seconds
Press "Soil Level" button and hold until "88" lights up on the display and all indicator lights turn on
Watch the display flash any error codes will be displayed. e.g. "81" , "F", etc
Take a note of the numbers and letters displayed, press the "Soil Button" and the next set of codes will be shown. Press the soil button a few times noting down all the codes until "88" is displayed.
If the "Soil Button" doesn't work try another button using the same procedure above exluding any of the buttons mentioned above.
Please post the error codes you have noted.
Oct 13, 2014 | Washing Machines
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
How to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Jun 17, 2009 | Panasonic Televison & Video
Intermitent start up
my friend had a similar problem with a panasonic combo unit it needed resetting what we did was hold the power button on the unit for about ten seconds we had to do it a few times but eventually it reset itself then went into standby mode its worth a try hope this helps regards JIm
Apr 29, 2009 | Panasonic DMR-E85H DVD Recorder
The language on my printer screen appears to be Chinese. It used to be English, but my grandson pushed buttons and I don't know how to get English back. Help-- it is a Lexmark X3470.
How to Change the Display Language on a Lexmark X3450/X3470/X3480
  1. Turn off the power by pressing the Power button once.
  2. Then press and hold both the Start button and the Power button.
  3. Once the screen displays Mfg Menu enabled, release both buttons and wait until the display shows Copies:1.
  4. Press the Mode button three times. All the indicator lights will go out and the screen will display LCD button test.
  5. Press the up arrow (pattlnk_692006_1047-up%20arrow.gif ) once. The screen will display Clean NVRAM.
  6. Press the Start button once. The printer will be reset. Afer a few seconds, the message Language: English will appear on the display.
  7. Press the up arrow (pattlnk_692006_1047-up%20arrow.gif ) until you reach your preferred language. Press the Start button once, then the Menu (pattlnk_762006_1319-menue.jpg ) button.
  8. Turn the printer off and then back on to disable the manufacturer menu (Mfg Menu). NOTE: After clearing the NVRAM, you will need to print an alignment page. The printer LCD will display this while the alignment is being performed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Lexmark X3470 All-In-One InkJet Printer
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
Colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
