Question about D-Link DI 514 Wireless Router (DI-514)
Login for d-link 524
What is the default login and password for d-link router 524?
Thanks!
  • Anonymous Mar 21, 2014
    forgot password
  • 450 Answers
TRY: admin , Admin
OR :user , User
You can also look here for similar D-link default passwords:
http://www.irintech.com/x1/blogarchive.php?id=764
Hope this helped, if helped, Please vote!
Posted on May 15, 2010
  • 109 Answers
You can try some of these combinations:-
Username Password
admin (blank)
user user
user (blank)
(blank) private
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Hope it works for u
All The Best!!!
Zooless
I reset my computer to original setting and forgot to write down my wifi password. How do i recover it?
You don't - you reset the router with the button at the rear and you login into it using the default one (admin) and do all the setting again as explained here
http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/
Sep 19, 2011 | D-Link AirPlus DI-524 Wireless Router
I lose my original cd kit installion for d-link di-524
You don't need an installation CD.
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 23, 2011 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
I need to reset my password, my thing has been broken into.
To reset your router, keep pressing on the "reset" until it resets by itself. This will take it back to factory settings. Then you can log back into it by going to http://192.168.0.1 once it is back on.
The default login is -
U: Admin
P: <blank>
This should get you back in, but you will need to reconfigure password and encryption if you had any enabled. Also, I would recommend changing the default username and password on the router to prevent hacks from neighbors.
Hope this helps! Thanks!
Oct 21, 2009 | D-Link AirPlus DI-524 Wireless Router
I want to put a password on my D1-524 router
then you need to login on your router. connect to it with the routers ip address and login with usr: admin and pwd admin, then go to system and change password.
Oct 12, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
  1. Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
admin username: admin
Default admin username: admin Default admin password: <blank>
Aug 16, 2009 | D-Link (DWL-2200AP) 802.11g/b Wireless...
Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Mar 13, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Ip address
By default the IP address should be 192.168.0.1.
If it will not accept it
>Make sure your computer is wired or connected to your DI-524
XP version
>Try going start>run > type in CMD
>on the black screen type in ipconfig and hit enter.
>Look for the Default Gateway that would be the IP address that your DI-524 is using.
Windows Vista
>Click Start>All Programs > Accessories > click on command prompt
>type in ipconfig
>Look for IPV4 for the Default Gateway and that would be the IP address of your router.
If not allowing to access the login page, try pressing the reset button for 15 seconds at the back of your DI-524 but pressing the reset button will reset the setting of your wireles setting. Once your press the reset button type in 192.168.0.1 on the address bar and you should be having the login page. use Admin/admin for the username and leave the password blank and click ok...
Jan 31, 2009 | D-Link AirPlus DI-524 Wireless Router
Using wireless connection with plugged in computers
Reset the router to factory defaults by pressing and holding the reset button for about 10 secs. The router will reboot (this will take a few minutes) and you can login using "admin" and blank password. The default address is 192.168.0.1
Hope you will reclaim your router.
cheers.
Jul 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Logging onto the DI-524 Router
hello..
The default username for the DI-524 is admin and the password is blank.
Jul 02, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
