Question about Kitchen Ranges
Ooven door not closing properly staying ajar - Kitchen Ranges
  • 2 more comments
  • Sagrecy May 10, 2008
    Kenmore door will not close completely.
  • hadafarm May 22, 2008
    I have a sf360
    and the door does not close all the way
    any help would be great
    thanks
  • m8954 Sep 23, 2008
    I have the same problem w/ door to the small oven - HELP!!
  • robert samples May 11, 2010
    whats the brand and model number
The one or both of the door hinges are bent. The hinges are built into the door which must be removed to replace them. Hinges cost about $24 each. There are several web pages that mention this problem, such as: http://www.fixya.com/support/t479847-kenmore_ceramic_top_electric_stove_door
Posted on Apr 14, 2008
SOURCE:
How do I make my hatchback door on my estima close properly.
adjust the latch so that the door closes better. You may have to use a lever and brute force to bend the latch and panel back into position if the adjustment is not possible.
Dec 31, 2014 | Cars & Trucks
04 EXPLORER DOME LIGHT STAYS ON, DOOR ADJAR LIGHT ON, DOOR JAMB SWITCHES WORKING PROPERLY.
At least one of your door ajar switches are sticking. Try spraying rust penetrant into the latches and open and close the doors several times. If they still stay on you will have to locate which latch it is by removing the door panels and disconnecting the switches.
Feb 24, 2010 | 2004 Ford Explorer
Dead battery, door ajar lights stay on, is seners not working?
Make sure all doors and trunk are properly closed. If light still stays on, you'll need to track down which door switch is causing the problem. Also make sure the interior light switch on the light controller is switched off.
Aug 16, 2009 | 2003 Dodge Caravan
Passenger door ajar
it sounds like a bad door switch, does the dome light stay on also? if so, it is a bad door switch.it is also possable the switch is adjustable and you can try each of them individualy by pushing in the tab in the door jam that looks like a "turkey timer" (but it is black)..good luck, marty
Jun 11, 2009 | 2005 Chevrolet Uplander
2001 Mazda Tribute, V6, 4wd..........Door ajar light on, but door
The door switch is stuck on or the wire is shorted to ground.
Jan 19, 2018 | 2001 Mazda Tribute
Door ajar light on
The drivers side door switch goes bad all the time on those, try replacing or check if its sticking.the small little button int the door jam.
Feb 01, 2009 | 2002 Ford F250 Super Duty SuperCab
Interior Lights and Door Ajar light stay w/beeping noise.
Try spraying WD-40 into the door latching mechanism (door side). I learned this fix after two battery replacements, but have only had to spray twice in the more than seven years of ownership
Jan 20, 2009 | 1998 Ford Expedition
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Door ajar indicator stays on
you may just need to adjust your door jams they may not be closing properly, the other thing you can try is opening one door at a time and putting your finger on the switch usually in the lower l/h corner of b piller and see if the light goes off if not this may be the problem and replace the switch
Dec 18, 2008 | 2003 Toyota Corolla
Kitchen Ranges Logo
169 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
