Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Click'n connect can't discover the router message in Quick Insta
    Genius:
  • 1,354 Answers
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless.
Posted on May 15, 2010
Help with d-link router please
Thanks, konafaa. Sometimes the best procedure is to start over from the beginning, as you discovered.Best regards!
Apr 19, 2012 | D-Link Computers & Internet
No internet access
Disable all the firewalls on your computer, ensure that the wireless card on computer is on and is working fine. ensure you entered the right network key.
Oct 04, 2008 | NetGear RangeMax WPN824 Wireless Router...
Hi i am getting an error message clinkn connect can't discover router. please check the cable connection and make sure the router is powered on
This could be a cable fault.You can buy simple cable checkers at aPC store.If this isn't faulty,try uninstalling and then reinstalling the disc that came with it or going to device manager clicking on modems and seeing if your router is there if it is right click on to it and click update driver.RESTART THE COMPUTER.
If this didn't fix it,try unistalling the modem from device manager restart the computer and the windows system will try to find a driver for the modem.Or you could try searching for the driver in browse when you update the driver.IT GETS COMPLICATED I KNOW I'VE DONE IT THOUSANDS OF TIMES.WINDOWS 7 IS A GOOD OPERATING SYSTEM THAT FINDS DRIVERS AUTOMATICALLY FOR YOU.
IF YOU AINT GOT IT GET IT NOW.UPDATE YOUR PC.
Aug 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Im unable to connect yahoo messanger most often
you must be making some mistake in username or password
or else
try uninstalling and then again insta;;ing it back
good day
Jun 01, 2010 | Yahoo Messenger
I got A quick cam logiteck fusion but I cant install it in my cumputer ? I got windows 7 please can you give the drivers suitable with windows 7
This webcam is supported for W7 - visit the logitech website and browse the photo gallery
Click on your webcam and then click "Downloads"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
May 21, 2010 | Mri WebCam
Router setup gets Error 302 message
Old configuration parameters are lost. Check with your service operator for a fresh config details to enable the router in gateway mode.
Oct 18, 2009 | Computers & Internet
Hi I live in Australia and have brought D-link dir-300 Wireless G router 1st off I have on screen D-link Quick router setup Quick router set has discovered that you are already connected to a router...
Dlink routers are fairly easy to set up most of the time, I've used several of them over the years. What the heck is this tower you keep speaking of? Is it a second computer or is it THE computer for your desktop monitor. Your explanation leaves a lot to be desired. I've never seen a commercial router that stands up like a tower computer and if you have one, it is probably a pretty expensive unit, so we must clarify and completely understand what you are talking about. You indicate that removing power and cables from the tower would disable your monitor and that makes it sound like the tower IS your computer. Does that make sense to you, it does to me.
Aug 24, 2008 | Computers & Internet
Wireless conncection
depending on who your ISP is, you need an ethernet cable coming from the modem into the WAN/Internet port on back of router. Once that is in you can try to connect wirelessly using the settings your router is setup for :
SSID/network name
encryption type
encryption key/passkey/passphrase
-- this part is dependent on above setting
wireless channel
Jul 08, 2008 | MSI Wireless-G RG54G3 Router
No Internet Through the Router
If changing from a dial-up connection, see warning at bottom. Troubleshooting Steps 1. Connect your computer directly to the modem, without the router. If you cannot access the Internet, contact your ISP. 2. Reconnect the router, modem, and computer as they were before Step 1. Can you log on to the router? If not then: 1. Check that all cables attached to the router and computer are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot light status, as explained in the router manual. 3. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual. 4. Check if the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue this document. If the adapter is not NETGEAR's, contact the manufacturer. 5. Power off the router. 6. Power the router on again. 7. If you still cannot log on to the router, then do a hard reset on the router, as described here: http://www.fixya.com/ThreadView.aspx?thi... 8. If you still cannot log on to the router, Contact NETGEAR: http://kbserver.netgear.com/kb_web_files... . 3. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 7.) 4. If a dynamic IP address is discovered, go to Step 8. 5. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 8. 6. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 8. 7. If the Smart Wizard does not find an IP address: 1. Power off the router. 2. Power off the modem. 3. Power on the modem. 4. Power on the router. 5. Go back to Step 3. 8. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access! 9. If the page does not display in a minute, check here: http://www.fixya.com/ThreadView.aspx?prd... . 10. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the modem, router, and computer, in that order ? waiting for each to completely reboot before rebooting the next. 11. If the modem's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are not greyed out, then settings for a dial-up connection are being used. Warning: If you are a dial-up user converting to a cable or DSL connection, some software will not work when both types of configuration are present. Configuring your new connection may stop your dial-up connection from working. You may have to configure to connect one way or the other.
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
Feb 19, 2006 | NetGear RP114 Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
2,543 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
