Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
My pc often functions very very slowly.It has a 128 Mb RAM with 1.80Ghz processing speed. What to do?
  • Adnan Bhatti
    Adnan Bhatti May 15, 2010
    Which Windows version are you using.
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Thanks
Posted on Jul 01, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 99 Answers
Just you remove the temp file by typing the following command in the run : %temp% temp
The above both command will remove the temp file and help somewhat in speed up your PC. But I would recommended you to upgrade your PC if possible.
Posted on May 15, 2010
    President:
  • 1,619 Answers
Remove and unistall software and programs that are unused. Then use disk defrag and cleanup to take care of the rest.
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
Sep 27, 2014 | Computers & Internet
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Thankx for ur reply this is my ram config. i think it is compatible to each other. 512 MB DDR PC3200 128 MB DDR PC2700 Maximum Memory Capacity: 2097152 MB Currently Installed Memory: 640 MB Available...
I am glad to hear that your PC is running well. If you need any help again in the future we will be here. This is something we like to do, so there no having to tolerate at all. Only us helping you to understand your problem.
Nov 12, 2009 | Baby Gear
Will Windows XP work on a Compaq 5020?
Yes, but it will be somewhat slow on such a old computer. I would recommend getting a new computer or buying a newer used computer, for example from ebay.
Sep 04, 2009 | Compaq Presario 5020 (320830-003) PC...
Upgrading my 128 RAM of KOB 810e FST MB
Looking at the manual for this motherboard your maximum ram is 512mb in two sticks of 256mb each. Speed rating is pc133 (maximum). You may struggle with the external hard drive as you only seem to have usb 1.1 and not usb 2.0
Jun 05, 2009 | Computers & Internet
About Graphic Card
most be your both ram FSB is not same , if yes you need same FSB ram
May 29, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
HP deskjet requires minimun of 128 Mb ram. My computer has 128 Mb ram but the printer doesn't still works.
First uninstall the printer driver and restart the machine then again reinstall the printer driver using typicall settings , after installing the driver again restart the machine then check
May 26, 2009 | HP D1560 Deskjet Printer InkJet
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
Ram
Check the configuration of your system, it probably supports 128 MB of RAM at max.
Jul 16, 2008 | Compaq Presario 5000 PC Desktop
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
