Question about Velbon Sherpa DV7000 Tripod
Fluid in velebon tripod
What is the fluid in velebon fluid head tripod?
  • 685 Answers
I cannot tell you esactly, but it seems to be more of an oil or grease than a liquid.
Posted on Jun 25, 2010
Can you use the Davis & Sanford FM18 tripod head with a Canon Rebel camera and 150-500mm lens?
You should be able to, there is nothing about the camera or lens that is incompatibl with that tripod. Just make sure the tripod has all its parts.
Apr 24, 2014 | Sanford Davis & ProVista Airlift Tripod...
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
I have what was a BOGEN MANFROTTO TRIPOD 3246 WITH 3047 FLUID HEAD PLATE that is discontinued I'm looking for the user manuals.
There really are not user manuals so to speak. If you need service or repair try: http://www.manfrottotripodparts.com/repairs.html If you are looking for more tripod use info try: itripod.com
Apr 03, 2013 | Manfrotto Photography
What fluid do i need in my 3066 tripod
they don't use fluid - maybe some grease in the tilt and pan of the head, but the tripod itself doesn't need any.. you might need an adjustment somewhere... I own 3 of these.
Feb 07, 2013 | Manfrotto Bogen 3068 Tripod With Bogen...
Head for fluid solidex tri pod
Solidex is not a tripod for which parts can be gotten. Most of the Solidex tripods do not have removable heads. Try anther brand. You can find a bunch of very good tripods at: itripod.com UI like the Sirui brand
Dec 04, 2012 | Photography
Remove 3130 head from 3021 tripod
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Apr 23, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
Fluid head platform is moving before the fluid
Below the head where it attached to the center column is a set of three screws. Back them out a little bit and then tighten the head, then screw those three grub screws back in to lock the head.
Apr 04, 2010 | Bogen Communication Bogen Manfrotto 3046...
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Jul 02, 2007 | Bogen Communication Bogen - Manfrotto...
Pan control not fluid when tension increased
Sounds like you might have gotten some dirt trapped under there. You might try to loosen it and blow it clean.
Apr 16, 2007 | Sunpak Video Pro M Tripod
Velbon Sherpa DV7000 Tripod Logo
172 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
