Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Sensomatic Water never comes on. Everything looks fine, all electric looks ok, no water in bottom. I turned it on, opened it to add a spoon, closed it and the water never started running
  • dianeb152 Mar 30, 2008
    model # SHU5306UC/U12
    Scholar:
  • 58 Answers
Do you know your model number?
Posted on Mar 30, 2008
  • Wayne Card
    Wayne Card Mar 30, 2008
    it could be a water tempurature issue ... the machine will not start until the internal water temp reaches a certian temp... is there anything displayed on the control panel?
  • Wayne Card
    next thing is to check the water valve connections ... it shopuld be located behind the kikc plate at the bottom of the washer
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
Water coming back into bosch dishwasher
Check the drain hose that goes into sink cabinet. It should loop up as high as it can go so that water from the sink or disposal doesn't siphon back into dw.
Apr 08, 2015 | Bosch Dishwashers
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
My water heater wont refil with pressure
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, water heater forum, fixya links, disclaimers, and for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Bosch AE-9.5 Electric PowerStar PowerStar...
My dryer is leaking from the bottom. service man said either the tube or the pan is cracked. tube seems ok, so is the pan replaceable or glueable. could there be another reason to look for leak. dryer has...
Open the bottom front panel. Remove the heat exchanger. Take notice to see if theres any water in that compartment. Reach your hand towards the back of that opening to see if there is water pooling back there. If theres water present, then your condensation pump needs to be replaced.
also double check the connection of the drain hose from the dryer to the drain.
Jan 09, 2011 | Bosch Axxis WTL 5410 Electric Dryer
No water in kitchenaid dishwasher -- everything dirty and dry after wash cycle. rinse cycle the same. any ideas what might be wrong?
Simplist reason for no water in a machine that has been working well, is to check to see if the float, that is telling the machine to add water or stop because it is full, is stuck. I have had a measuring spoon fall out of its tray and fall under the float located in the bottom of the unit and hold the float up telling the machine it is full of water. It usually looks like a mushroom and should bob up and down.
Oct 03, 2009 | KitchenAid Dishwashers
Fisher-paykel dd203 started filling with water with drawer open
what you can do is take a baster and empty out the water; then check and see if anything is at the bottom of the machine inside meaning under the thing that twirles and anything that is long put on top rack.Because you can something that is stuck or gunk that is blocking the way
Oct 23, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch dishwasher still some soap left on dishes
Most of the causes of the problem that you are describing are related to the way the dishes are loaded in the unit. To test this, run it empty and see if the dish soap dissipates.
Mar 17, 2017 | Bosch SHU3305 Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
75 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
