Question about Hayward H400idl2 400,000 Btu Low Nox Heater Natural Gas
My service light is on and I have a bO code. The heater will run some times, more time than not it will not run. Thanks Dave
  • 64 Answers
The bO code is a normal code. It stands for bypass operation and just means that the heater is wired into an automatic controller such as a jandy or aqualogic. If there is a call for heat and the heater doesn't fire, you should be getting an error code. It may take several (3 or so) attempts at firing before you will get the code. HTH
Posted on May 19, 2010
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
Oct 12, 2015 | Whirlpool Dishwashers
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
BO code heayer keeps cycling on and off
check to see if proper gas pressure call gas company give them added total thems all your appliances use they probably will give you a bigger meter then everything will run efficiently
May 24, 2014 | Hayward H-series Electronic Gas Pool...
Have a bo code heater keeps cycling on and off
BO code is bypass operation. It means that it is set to operate with an external controller. Things like Aqualink, Aqualogic, Intellitouch, EZ-Touch are all types of automation / external controllers. They have their own temperature sensor and allow remote control operation. To truly find the nature of your issue. I'd start by taking it out of bypass operation and see if the unit fires by itself ( without automation hooked up to it ). The fault may lie with the automation system. You never know.
Clean light blinks
clean light blinks is a form of error codes. The most common is a heater circuit error, 7 times then a pause is the heater. to clear the code press the heated dry then normal in a key dance 4 times. this starts a diagnostic cycle, takes several min to complete. let it run. it will work until it sees the fault again. this code is caused when the main control does not read a water temp increase 3 times in a row. If this continues call for service.
Jan 08, 2012 | Maytag Dishwashers
"bo" when turns on then goes to service and shows
Bo means bypass operation which means the heater is being controlled by an outside control. There are 2 togs on the back of the board that control this function
Jun 19, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
My pool and spa heater is not working diplays service codes bo and AO
MAKE SURE THE FILTER IS CLEAN THAN THE TEMPETURE SENSOR MAY BE BAD, CLEAN THE FILTER FIRST
Oct 10, 2009 | Hayward H Series Pool & Spa Heater 400k...
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
1991 Chevrolet S-10 Blazer starts but won't run for long.
dave when is the last time you did a tune up? or cleaned the fuel system
Nov 01, 2008 | 1991 Chevrolet S-10 Blazer
Konica Minolta Bizhub 250
I've had this a couple of times. Bit of a pain the black & white 250's for this fault.
Basically when you change the drum (and dev) you need to go into service mode anf run an F7 asap.
If the machine doesn't allow you to run an F7, you need to go into counters and reset the drum/dev one.
Bit of a pig cos all you're hearing is 'bee-bo-bee-bo'!
Feb 13, 2008 | Office Equipment & Supplies
Hayward H400idl2 400,000 Btu Low Nox Heater Natural Gas Logo
625 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
