Question about Maxent MX-50HPT51 50 in. Plasma TV
My Plasma maxent MX50HPT52 has power but no picture or sound? Repairman says Maxent he thinks it is a circuit board but Maxent has no website or directory to order parts or even a troubleshooting manual.
  • 4,889 Answers
He is right it is most likely to be the main audio video board that is faulty. That explains why you dont have picture or sound. It may be possible to perform a component level repair but I have found no repair manual in my collection too. However these exotic brands use components manufactured by the original brands. If you can get me the part number of the main audio/video board then I can help you find a repair manual that has schematics of that particular board.
Posted on May 15, 2010
  • Altafio Oct 01, 2010
    I have the same problem with my TV. The part number of the main audio/video board is B.ZRAT3C-2. I can't find that part # even I tried ebay, ShopJimmy, Discount Merchant etc. I also seeking help with that part. Thx
  • eagle338
    eagle338 Oct 01, 2010
    I will look for the part and let u know if I find one.
Maxent MX42X3 42" plasma Monitor..
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
Jun 03, 2011 | Maxent MX42X3 42 in. HD-Ready Plasma...
My 42" maxent tx went pop and the picture is
When they say the board I would think the power supply board ( unless they meen the whole screen itself)is the problem, In my experience the problem may not be that costly, If it went pop I assume the fault caused the fuse to go ( the one inside the tv), if so it could be a small component . It may be repairable for less, at least get a second opinion.
Unless the power supply needs a total rebuild or the screen itself it shouldn't cost that.
pete
Nov 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
My maxent mx50hpt52 in picture is very faint what would cause this and how do i fix it
HI; MOST LIKELY CAUSE IS "Y SUSTAIN" BOARD. TRY TO FIND ONE ON EBAY. IF ATTEMPTING TO FIX THIS YOURSELF, BE VERY CAREFULL TO MAKE SURE THE POWER SUPPLY IS COMPLETELY DRAINED BEFORE REMOVING BOARD. ALSO, WHEN INSTALLING NEW BOARD, KEEP IN MIND THAT IT IS VERY SENSITIVE TO STATIC DISCHARGE, SECONDLY, CONNECT THE RIBBON CABLE ON BOTTOM RIGHT OF BOARD ONLY AFTER ALL SCREWS ARE TIGHT AND OTHER CONNECTORS ARE SEATED ( MAKE SURE THE RIBBONCABLE IS FIRMLY SEATED AND LOCKED DOWN). AFTER INSTALLATION,CONNECT SET TO A VERY GOOD SIGNAL SOURCE, AND ALLOW SET TO WARM UP FOR ABOUT 20 MINUTES, THEN (USING LARGE, CLEAN MIRROR) SLIGHTLY ADJUST "SETUP AND SETDOWN" MINIATURE POTENTIOMETERS UNTILL THERE ARE NO SPARKLES.
GOOD LUCK!!
Oct 13, 2010 | Maxent MX-50HPT51 50 in. Plasma TV
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
Maxent plasma tv mx-42hpt52 when switch on everything works well for about 5min then volume goes to max on its own and other fuctions stops working.
You need to have your main board replaced. It's unfortunate but even low voltage boards go bad. Try locating a Maxent website and email them to see where you can get parts from.
Mar 10, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Tv screen is green
Ur Main Tuner Signal board is the cause.Replaced this Main Tuner Signal board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Signal board for replacement.
Mar 02, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
May 19, 2009 | Maxent MX-42V1 42 in. Plasma Television
Maxent MX42X3 first on
If it flickers on start up it will only get worse. Mine got were it took over 3 hours to settle down, and never would stop flickering with DVD'S. Solution for mine: Replace bad capaciator on input circuit board, I found it by using a heat gun to speed up coming on process, Cost me 62 cents to replace the capaciator my self.
Mar 03, 2009 | Maxent MX42X3 42 in. HD-Ready Plasma...
MAxent plasma will not turn on
open the back and reseat the LVDS cable(looks kinda like a computer data cable)...also check your other circuit board connectors..literally unplug the connectors..and reseat them...Question...is the set working now?...or is it not coming on?
Jan 16, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent-42" HD Plasma
i havn't been able to get a tech manual yet for this unit..however...the plasma display has lost power...i would replace the X board and Y boards, including the Ysus boards(upper and lower Ysus boards.
Nov 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-50HPT51 50 in. Plasma TV Logo
197 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
