Question about Linksys Wireless-N WRT150N Router
Can't access the linksys router page 192.168.1.1
  • 4,281 Answers
Try 192.168.0.1
Or press RESET button of router for 10 seconds so all settings defaults then try with above ip.
Reset button is in back side of router.
Then you can access it with 192.168.1.1 or 192.168.0.1 .
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 15, 2010
5 Suggested Answers
SOURCE: Help please
change private lan in modem or router and then try again. 168 is being automatically assigned by one of those devices
Posted on Dec 09, 2007
govinda123
  • 2263 Answers
SOURCE: I can't access my linksys router set-up page. I
" 401 unauthorized" authorization required " .This message means the user name and password for the router is not correct. the default password of the Linksys router is admin with no user name ( leave it blank )
If the default password is not working then the router password must be changed.
If you don't know the password of the router then you will need to reset and reconfigure the router.
Once you reset the router , it will come back to the factory default settings.
Click here for more info about router and network
Posted on Jan 08, 2010
Tom Marvolo
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
Can't access internet, says I am connected but then says no internet connection
I think you should try to reset and reconfigure the Linksys router and see if that works.
If your Linksys router is old then you can also upgrade firmware on the router.
Connect your computer directly to the modem and make sure that you can access Internet directly through the modem.
Connect the modem and computer to the router. Open the setup page of the router and change the settings manually.
Try this website to setup your Linksys router manually.
I can also suggest you a Fiverr Gig where you can pay only $5 and get support for your Linksys router.
Jun 11, 2012 | Linksys Wireless-G Broadband Router
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
The Cisco System logo just stays orange, I attempted to repair on my lap top but it won't let me repair.
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 09, 2010 | Linksys Wireless-G WRT54GS Router...
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
Try:
Resetting the Linksys Router to Factory Default
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 08, 2010 | Linksys Wireless-G WRT54G Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-N WRT150N Router Logo
147 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
