Question about Kettler Exercise & Fitness
Treadmill won't start
Hi
A week ago i transport my Marathon HS to my new apartment but since then it won't start.
I checked the cables and fuses but i cant find anything wrong i really have no idea what else i should check.
    President:
  • Kettler Master
  • 832 Answers
If you have a multi meter I would first check the AC outlet follow the path (power cord, on/off switch, fuse holder, motor control board) to see if their is any power interruption . Also I have to ask is the safety lanyard attached to the upper console. Hope this give you some direction.
Posted on May 15, 2010
Testimonial: "thanks for the help. I checked all connections and there wasn't any power interuption anywhere. But even though there is power the light at the power button doesn't open. Yes the safety Lanyard is attached to the upper console."
  • John Mazmanian
    John Mazmanian May 18, 2010
    On your motor control board are their LEDs and are some lit this tells you that AC is being feed to the lower and 5v dc to the upper console.
    When you hit the start button does one of the light start to flicker this you PWM.
    This a signal generator its sent from the upper console this lets you know that upper console and cable is good. Let me know
    Regards
My kettler tx1 marathon running machine causes the electricity to swith off in the house. This occurs when I start the treadmill, not when I simply switch it on. Any idea as to the cause?
The motor or the Motor control board is faulty. Can be the motor brush or the shorted igbt transistor in the motor contol board. If you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Sep 28, 2016 | Kettler TX1 Treadmill
I have a 2006 new beetle, just put in a new battery about a week ago. It drove fine. My problem is, the car won't start when i turned the key. I tried many attempts, but just won't budge. Is
Hi there, with this kind of problem in general, you have to look on any source from where your battery is being drained. Check your new battery if it is drained again. If the voltage is below 12V means there is a close circuit that is using your battery while it is stopped. Recharge your battery and try starting your car or ask a friend to jump your car. If it wont start check your starter motor. Another factor to think of is maybe your alternator is not charging your battery.
Mar 26, 2013 | 2006 Volkswagen New Beetle
Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 19, 2012 | Horizon Quantum II Upper Control Board
1998 Ducati Monster 750 won't start. Ticks over ok, but won't "fire". New fuel in tank only two days ago, ran several trips since, just won't start now. Tried push-start, sounds like...
Hi, Mlyndon and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati Monster won start fixed see how
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Aug 31, 2011 | 1998 Ducati Monster 750 - Dark - City -...
Hello ! I am from 2 weeks a new kettler marathon tx 1 tredmill. Few days ago when I want to modify the rising angle , this one is out of order. So after it I saw that on the display is not shown the angle...
DEAR
I THINK YOUR HAND BAR KEY INCLINE STUCK YOU SEE IT AND FREE THE KEYS STUCK .IF NOT YOU MUST GUESS ELECTROSTATIC ELECTRCITY WHEN YOU RUN ON AND TOUCH HAND BAR YOU GUESS A FEW ARC THIS IS BECAUSE OF YOUR BELT IS DAMAGE AND THE ELECTRICITY DAMAGE YOUR MONITOR AND YOU MUST REPAIR IT .
you can countinue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 28, 2017 | Kettler Exercise & Fitness
1989 heritage softail clutch play at handle disappear . New clutch plates , bearing and cable about year ago. Problem started about 4 months ago , Set clutch up according to manual , but problem was back...
take off your trans door cover and check you snapring on your ball ramp assembly and check to see if all three balls are in place if that looks ok try lubricateing cable also check cable adjuster i had one that the threaded part was cracked where the threads start and every squeeze of the clutch brought a different endplay
Oct 18, 2009 | Harley Davidson FLSTC Heritage Softail...
Multi coloured lines all through display
Sometimes the video cable is loose in one end and/or the pins in the cable are twisted. Try to reposition the cable or buy a new one (they are very cheap) Sadly, if you cleared that one up, then the monitor is probably faulty, try it in another computer,if it does the same you will need to take it to service.
Oct 28, 2006 | LG Flatron L1710S 17" LCD Monitor
Exercise & Fitness Logo
530 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
