Question about Car Audio & Video
I am trying to install my sony xplod cdx-f7700 in my 2001 toyota echo and when i tried turning it on after i connected all the wires(used a wiring harness adapter) it jus didnt turn on at all...i checked and replaced the fuse and now it still wont turn ...the one time i did turn it on i was able to eject the cd but nothing else....now it does not work at all.. any suggestions?
    President:
  • 1,619 Answers
Get a multi meter and double check the power to the unit. Also check and make sure the ground wire is actually grounded. Check the fuses to be sure you have power. Double check your connections to the adapter also.
Posted on May 15, 2010
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
Where does the remote wire for amp go to on sony xplod cdx gt520
their should be a blue white wire on the back of the radio. this wire is called the amp turn on wire connecting to this wire will provided 12 volts when the xplod cdx gt520 is turned on but if you press the off button on the radio the 12 volts will drop to 0 volts but when the radio is turned on the 12 volts will come back.
Aug 01, 2011 | Sony CDX-GT520 FM / AM Receiver
I recently installed my sony xplod to my jeep and the radio, volume works fine. when i insert a cd, i hear nothing, counter and track displays but no sound...please help
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Feb 17, 2011 | Sony XPlod CD Player w/MP3 Playback...
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
I want to install a Sony CDX-SW200 cd player in my car and need to find a wiring diagram. Where can I find one?
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Feb 23, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
Need color code for wires to connect to my 94
The ling below will help you get the wiring for these kind of Xplod stereos...
http://forum.ecoustics.com/bbs/messages/4/336658.jpg
Aug 30, 2009 | Sony Car Audio & Video
Installed the sony xplod
You may have used the dimmer wire to ground your radio and blown your fuse. First unplug your radio. This problem can be checked with a multimeter by seeing if the wire is grounded with the car off. Turn on the lights and see if it reads 12 volts on that wire. If so, use another ground wire or attach it to the truck's chassis earth.
Jul 06, 2009 | Sony XPLOD CDX-GT200 CD Player
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
Sony cdx-gt21w
If you stop by any car stereo shop, you should be able to purchase a wiring harness that will plug into your car's plug. You can then wire it up to the wires coming from your sony by matching up the standard wire colors.
Sep 13, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
