Question about Linksys Wireless-G WUSB54G 802.11g/b
When i plug it in , its shut my computer off , it continue to do that for about an hour or more before i can connect to the internet without my computer being shut down , what should i do ??
    President:
  • 1,619 Answers
Sounds like your usb power is low. Either get a new usb card or use a powered hub, or try another usb port on the computer.
Posted on May 15, 2010
L navigate withe the connection but the notification shown that there isn't aces to the internet
Unplug the wireless access point, shut down computer, plug in wireless access point, wait for selftest, reboot computer. Without know what you Router is and your computer, that's the best I can do.
Dec 14, 2012 | Computers & Internet
Beeper wont shut off
Remove the power plug and Allow the voltage present on the board to drain OFF. After an hour please recheck and if the beep still stays there is fault in the motherboard. Possible that the beeper driver is short and is continuous. If all the other functions are working without any issues, all you can do is to cut off the beeper connection if you are able to remove the board and snip off . Attempt with power plug removed .
Nov 06, 2011 | GE JVM1850 1000 Watts Microwave Oven
For the past two months I can not totally shut down my computer without terrible problems when i reboot. Craxy horizontal lines and have to shut down and reboot several times to be able to resolve issue,...
if you have a plug in VGA card remove it and connect the monitor to the computer plug in
if the monitor is good , replace the vga card
next make sure that all files, folders and data is backed up on an external hard drive
on start up , when you get the desk top screen up
in the search bar under the list of programs , type in-- chkdsk and click on it when it comes up just above where you typed in
that will energize the self check of the computer , hard drive files and folders and everything on the hard drive
be prepared for it to take around 6 hours for the check as it checks and repairs any faults found for every file and folder and there could be over 3 million spaces to check
you will get a report and if there is a hard drive problem , you will get such a message
Oct 17, 2017 | AOpen A75PF Monitor
Does not connect 2 internet
Are you getting any error messages? Is your computer plugged directly into a modem, or is it connected directly to a router. Is the computer connecting to the internet using a wireless network card? If connected directly to the modem, shut off the modem, wait a few seconds and restart; also reboot your computer. If that does not work, go into device manager If you're running windows xp - it can be found by going into control panel - system - device manager and see if your network card is listed without any x's or other markings which indicate a problem with the device. If your network card is indicated with no markings, and it is not working, try downloading and reinstalling the drivers for your system's network connection device (you can get that from your system's support page). If your plugged into a router, or if your connecting to the internet via wifi, try shutting off and restarting the router. Reboot your computer and see if that works. If not, you might need to download and install a firmware upgrade for the router. This is relatively simple, and the instructions and appropriate download file can be found at your router manufacturer's support page. Try these and see which works. Good luck!
Dec 22, 2010 | Computers & Internet
Is this product compatable with vista? I have had this unit for about 6 years and has been in a closet. Changed my internet service and had this old router. It looks like I have it connected properly, but...
Routers are usually not OS dependable. Which means, yes it is. It is compatible. You need to go inside configuration and make sure your router is picking up IP address from your ISP. This is how to do it:
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down
your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the
WAN port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your
computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router
to boot.
7. Turn on your computer.
8. Verify the link lights on the router. The power light, WAN light, and the LAN light (the port that your computer is
plugged into) should be lit. If not, make sure your computer, modem, and router are powered on and verify the cable
connections are correct.
Now to configure router, do this:
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1). (no parenthesis)
Enter the user name (admin) and your password. Leave the password blank by default.
You may run the setup wizard to quickly setup your router. Click Setup Wizard to launch the wizard.
Click Launch Internet Connection Setup Wizard to begin.
Click Next to continue.
Create a new password and then click Next to continue.
Select your time zone from the drop-down menu and then click Next to continue.
Select the type of Internet connection you use and then click Next to continue.
Your connection is probably Dynamic, meaning your ISP is giving you IP address automatically and it changes. So, choose dynamic, and leave host name, mac address and everything else blank. Save it.
That should do it. You can also proceed to setup your wireless. Make sure you secure it also.
If any questions, let me know!
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Daewoo CT6720-C25 Computer continually freezing
Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Jul 29, 2010 | Computers & Internet
Internet shut down.
Try changing your power settings to Always On when downloading overnight. If the machine enters sleep or hibernate mode, it will drop any active downloads.
Jun 01, 2009 | Gateway Computers & Internet
Linksys Wireless-G WUSB54G 802.11g/b Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
