Question about Cycling
Need instructions for installing innertube into a bike tire
    Habit-Forming:
  • 25 Answers
Remove the wheel from bicycle.
Take the air off the wheel, by pressing with small screw driver or fingertip on the valve while make pressure on the tyre
With the help of a tyre remover lever or with somekind of non sharpie lever, put it between the tyre bed and the tyre and try to take the edge off the bed. Once you got one put another aroun one inch appart and repeat the procedure, then try to slip one of them all around the wheel and you will end with one side of the tyre off the wheel.
push the valve of the innertube in and pull off the innertube.
Put the new innertube inside the tyre and push the valve throught the orifice on the wheel.
By hand, try to put the tyre back on the bed, is good idea at this point put some air on the innertube, but not too much, just enought to get in the tyre and far from the tyre bed.
If not possible to put the tyre back on the bed by hand use the same tool to remove, but be very very carefull not to pinch the innertube, because is very easy to pinch it.
Put air on the tyre and put it back on the bicycle
Posted on May 18, 2010
My wheelbarrow has a flat tire, how can I change it?
Depending on the type of wheelbarrow you have and the tires that it takes you might just need to patch the tire and then pump it with air, replace the innertube, or replace the whole tire.
Jan 26, 2014 | Garden
Tip
How to Change a Flat Bicycle Tire
1) Begin by looking at your old bicycle tire, and find the dimesions of the tire on its side. Write down these dimesions, becuase you must then go buy a new innertube for the tire that is the same (or about the same) size. I suggest going to a bicycle store; at the one near me tires run about 5-10 dollars.
2) With this new innertube in hand, you can begin changing your bike tire. You must start by taking off the entire bike wheel. To do this you need a hexagonal-shaped wrench thingy that looks like this:
See the hexagonal wrenches on the left side? You're ging to need something like that to remove the wheel. If you don't already have one, you can get this one from here (Walmart.com), or you can look up 'bike tool' on Amazon or Ebay.
3) You then use this tool to remove two hexagonal bolts, one on either side of the wheel; shown here:
Then use a flathead screwdriver or another falt object/tool to pop the outer tire off to expose the old innertube inside, like this:
4) Remove this old innertub, and put the new one around the wheel. It might seem a little big, but that's okay. Proceed by slipping the outer tire back on over the new innertube, using the same tool you got it off with.
5) Put the wheel back on the bike, screw the bolts back in, and inflate the tire to whatever PSI (Pounds per Square Inch) it says on the side of the tire.
6) You're bike is ready to ride again!
on Feb 16, 2010 | Cycling
How to install front tire of mongoose bmx
Remove wheels, remove valve stem from innertube. remove tire by getting tire edge over rim. reinstall in opposite direction. If this seems difficult consult local bike shop for assistance
Dec 28, 2012 | Freestyle Mongoose Bmx & Owners Manual -...
How to remove back wheel from the frame to replace the inner tube on a Schwinn Sierra bike
to change the innertube you have to get something flat and put on in the tire and move the tire around tell it pops open
Apr 20, 2011 | Cycling
One of the rear tire innertubes went flat where can I find a replacement
Hi, most bicycle shops can supply replacement inner tubes for prams/joggers.
Hope that helps
May 30, 2010 | Baby Trend Expedition Double Jogger
Im looking for an innertube for my inglesina but
You have to go to a bike shop where they selll children bikes , if your tires size are the same as any children bike then they should be able to get you an innertube.
Apr 15, 2010 | Inglesina Ergo Cross 2-in-1 chassis for...
How do you change a innertube on a back wheel of a mountain bike
You have to remove the entire wheel from the bike. Then change it just like you'd change a front tire... remove oneside of the tire from the rim, pull out bad tube, clean rim, put in new tube, put tire back on rim, inflat tube... good to go. There are 1,000,000 videos on YouTube to show you this process.
Nov 08, 2009 | Bike Extreme Lite Youth Shoulder Pad
Any tips on putting a new inner tube into the tire
If you have had a puncture check the inside of tire for likely causes of puncture (nails tacks etc THORNS if moutain biking in the countryside. Make sure the inner liner is o.k. partially inflate the innertube. Line up the valve with the hole in rim gently insert the tube into the tyre working from either side of the valve . Check that the innertube is not pinching as you press tyre into position again working both ways from the valve. Squeeze the tyre between hand and fingers to ensure the it is properly positioned, inflate and off you go.
Sep 19, 2009 | Pit Cycling
We bought a Schwinn 12'' Roadster the end of November for our Granddaughter. One of the rear innertubes exploded, and we have been to 6 stores, including 2 Schwinn, and researched online, and cannot find a...
Just found the 10x2 tubes here. I am going to order today. I will let you know if I have any problems getting them from this supplier.
http://www.racemotorparts.com/products.php?id=1329
Mar 03, 2009 | Schwinn 12" Roadster Tricycle
Tyres
I don't have Freestyler myself, but friend of mine here in Finland found small innertubes and outer tires that fit to Freestyler 4 in hardware shop. They cost only few euros (4-8 dollars?)
I don't know about could bike shops have those also?
Tuomo
Aug 10, 2008 | Quinny Freestyle 4 Marina Stroller
Cycling Logo
194 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
