Question about ASUS A8N-E Motherboard
Asus A8N-E. No video. 1 long, 3 short beeps, but then SYSTEM BOOTS. I hear the floppy seek, then the drives working. After a minute, I can Alt-F4, 'U', which shuts off the system. Tried 3 video cards with the same result.
    Genius:
  • 1,027 Answers
That beep code means that the Video card has failed.
Posted on May 15, 2010
Testimonial: "Thanks "
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
A8n-sli deluxe one long beep and end. Please help. Thanks
Hi krzysio007! If you hear a beep once you start the system and it does not go away, this might be the CPU fan not functioning correctly. Try disconnecting the fan, cleaning the connectors and then plugging it back again. I have a similar problem with a motherboard just like yours, and usually the beep goes away after it boots into Windows. Since this motherboard has an Award BIOS installed on it try these error codes: Here. Hope this helps you with the problem!
Feb 28, 2011 | ASUS A8N-SLI Deluxe Motherboard
THE PC BOOTS TO 1 LONG BEEP, 3 SHORT BEEPS. THE BOOK SAYS DID NOT DETECT VIDEO. TRIED BOTH PCIEX SLOTS AND 2 DIFFERENT VIDEO CARDS. CAN'T GET OT TO GO ANY FURTHER!!?? WHATS THE LIKELY PROBLEM?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 27, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
I have a fujitsu seimens scaleo p computer with a asus pg5d1-fms motherboard. Everytime i start the computer up it runs for maybe five minutes and boots up and everything but it just shuts down. During the...
these are the meanings of those two beeps u're getting:
1 short beep : Normal POST - system is ok
1 long, 2 short beeps : Display adapter problem (MDA, CGA)
if u're still hearing 1 long and 2 short beeps then try to swap the MDA, CGA adapter around, if it is ok then that is the problem...MDA and CGA is just like the VGA card they supplements each other. replace MDA/CGA card with another then see.
Jun 17, 2010 | Computers & Internet
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
Asus motherboard cannot detect Seagate SATA drive
Does your internal speaker beeps or stops telling you there is no hd detection?
Try to put another hd.
If you are using Windows reinstall it.
Does the red light blinks
CHECK out the power chord to hd and all power connections from psu
Dec 11, 2008 | ASUS A8N-E Motherboard
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Apr 02, 2008 | ASUS A8N-SLI Deluxe Motherboard
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
ASUS A8N-E Motherboard Logo
1,068 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
