Question about Video Game Consoles & Games
I have the original nintendo game console. I re- cently bought a 32' Sony Bravia LCD HDTV (KDL-32BX300). My problem is the tv does not accept a signal from the game console. No video signal and the audio is just white noise. Is my game box com- patible with my tv?
    President:
  • 1,188 Answers
Its a very old system but there is no reason it should not work with a new TV as the standard connectors are present. Your Bravia has inputs for A/V cable and Component cables which look similar except for color. Perform the connections as follows:
Installation Steps:
  1. Locate the Audio/Video inputs on the back of the TV.
  2. Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
  3. On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the Controller(s) into the front of the system. Use the far left port for player one.
  3. Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
  4. Press the Power button in on the front of the NES.
  5. Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
  6. The game image should now be displayed on the screen.
Note that you must not confuse Component Input for A/V cables. You will find the location of inputs in the TV's user manual. Let me know if you are still unable to get a picture. Thanks.
Posted on May 15, 2010
Tcon BRAVIA 2010 sony kdl-32bx300
The T'Con is a built in part of the display panel, and cannot be replaced. The display panel should be replaced with a new one.
Dec 31, 2016 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony Bravia Bx 300 Blinking Light/Volume
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. You can get a clear idea about which board should be replaced.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 30, 2016 | Sony Bravia KDL-32BX300 32" 1366 x 768...
I have a Sony KDL-32BX300 showing vertical lines. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 30, 2015 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony Bravia KDL 32BX300 Error codes
Five blinks denotes an IRK error. To detect damaged components and to troubleshoot this error, you must have sound in electronics.
May 21, 2013 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Connecting a ps3 to sony bravia tv
DEPENDING WHAT IMPUTS THERE ARE ON THE TV YOU SHOULD BE ABLE TO BUY A LEAD FROM MOST ELECTRICAL/GAME OUTLETS
Dec 14, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
i have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
Aug 25, 2010 | Sony KDL32BX300 32 in. TV
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Mar 03, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Video Game Consoles & Games Logo
120 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
