Question about Nikon Zoom Wide Angle-Telephoto 28-85mm f/3.5-4.5 AIS Manual Focus Lens
Wanted to know how to change the settings on my lens
  • kakima May 17, 2010
    Which settings? You turn the zoom ring to change the focal length. You turn the focus ring to change the focus. Depending on the camera you're using, you change the aperture either by turning the aperture ring or by locking it at its minimum aperture (largest f/number) and turning a dial on the camera.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 21, 2010
Why won't my camera lense stay open
Its the power saving feature that retracts lens if camera not used for a set length of time.
If you want camera lens to stay open longer, change the settings by assigning a longer period of time.
Aug 17, 2014 | Cameras
I have nikon D90 SLR. with 18-135mm lens , i want to record a video with it but a videos quality is really low .. should I change a setting or something else?
Press the menu button and go to the shooting menu (the little camera icon). Scroll down to "movie settings." there are three quality settings. Select the one you want then try a test shot. The higher quality setting (1280 X 720 pixels) uses more memory. The default setting is 640 x 424 pixels and the lowest quality setting which uses the least amount of memory is 320 x 216 pixels. Sound is off by default so if you want to record sound with your video, you need to turn the microphone on in this menu as well.
Nov 25, 2012 | Nikon D90 Digital Camera with 18-105mm...
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n6006af/nikon_n6006af.htm
Mar 08, 2011 | Nikon N6006 35mm SLR Camera
I am getting little white dots starting to show up on my tv screen. It started with 3 and one by one i am getting more and more...i'm up to 13 now. it is an 50" Samsung DLP rear projection TV. Just...
Sound like you might have some dirt on the lens, color wheel, or lamp.
Unplug your set first before trying this.
If you are comfortable opening up the back of the set, you might try shooting a small puff of canned air toward the lens to see if the problem changes. Try not to stir up too much dust lest it cause other issues. If the problem changes, a good cleaning might be the solution.
Please call in an expert if you aren't comfortable taking apart the TV yourself. Check your manufactures recommendations fr cleaning your set.
Hope this helps.
Jan 19, 2011 | Samsung Televison & Video
Live view delay
Oddly I heard some one post a solution to a similar problem. The problem stems from having your camera set to " red eye correction" Taking it off this setting solves the problem.
Nov 25, 2009 | Nikon D90 Digital Camera with 18-105mm...
Is there a chart that explains the range of a lens. I have a Canon EOS and want to buy a zoom lens to shoot birds, wildlife etc. I don't know how far80-200 MM shoots. I know it's sounds like a dumb ?'s -...
Multiply the mm by 1.5 to get the actual range on a digital camera for any particular lens. Example...80-200 is actually 120-300mm. Then, to give you an idea of how that will look, every 50mm is like a 1x power on a pair of binoculars. Example...120=2.4 power, 300=6 power.
Sep 22, 2009 | Canon Digital Rebel / EOS-300D Digital...
Changing lens on oakley razor blades glasses
Firstly, remove your nosepiece. Grab hold of the frame at one of the top corners with an index finger and thumb - use your other index finger and thumb to hold the lens, apply presure and gently pull apart. The notch will release. To mount your new lens, insert one notch into the frame and press the other notch into place. Do not apply pressure to the stems or hinge.
Sep 04, 2009 | Oakley Crush OAK0333 Wrist Watch
How to change toshiba TDP-S35 lens
i got a problem with my projector, the colored break up into pieces, i want to know if how much is the price to repair it.
Mar 19, 2009 | Toshiba TDP-S35 DLP Projector
Problem with lens
if you cant afford it read this,
The reason for this is that I find it easiest to track a moving subject if it's in the middle of the viewfinder. Cameras cannot know what you want to focus on, and if you start using multiple AF points, how is the camera supposed to know that you want to focus on the bird and not the tree - cameras are lacking in human thought processes! What is quite handy though is using the AI SERVO FOCUS or AI FOCUS settings so that the lens will alter it's focus on the subject over which the centre AF point is aligned as it moves towards you or further away from you. Without this, the focus will fix at the point you half depress shutter and if the subject comes closer or goes further away then it will be out of focus. you can call any expert of lences also for it if you can afford.
May 22, 2008 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
How to change my lens on samsung e370
you have to stip the whole phone as i remember its a all in one front panel on that type
Dec 27, 2007 | Samsung SGH-E370 Cellular Phone
Nikon Zoom Wide Angle-Telephoto 28-85mm f/3.5-4.5 AIS Manual Focus Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
