Question about Kenmore 80809 Microwave Oven
Kenmore 665 68610891- built-in 1998 model
Fan came on by itself after 10 min cooking job will not shut off microwave works okay but fan will not shut off even when buttons are pushed to do so. Or if unplugged fan goes off(DUH) but fan on after plug in
    Problem Solver:
  • 9 Answers
Fan relay on circuit board stuck. Give it a tap (the relay), to free it up. Otherwise get the relay or driver transistor replaced. Easy fix. Take it to an electronic repair place, not the brand agent.(They,ll just replace the whole board).If this Item is under warranty you should not be wasting my time.:::Spiceweasel.au
Posted on Apr 04, 2008
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Kenmore microwave hood combination, The fan wont
With the full model number, chances are we could have helped you more.
If the cooktop lights recently failed, it may need circuit board repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Microwave Ovens
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Apr 25, 2009 | Kenmore Microwave Ovens
Microwave will not shut off Amana MVH230W/01 fan will not shut off.  While I was cooking on the range under this unit, the fan came on by itself and I can't shut it off.  Tried unplugging it several times...
Your hood fan thermostat is probably stuck "on" and will have to be replaced.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 01, 2009 | Microwave Ovens
Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Jan 05, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Fan keeps running
Neither the owner's manual nor the quick start guide for this model addresses that specifically, but most commercial microwaves do work this way to ensure proper cooling.
The manual does state that when you open the door then close it, the light and fan will stay on for an unspecified period of time.
If the word "HOT" appears in the display, the magnetron is overheated and the fan will run until the temperature is brought down.
If the fan fan NEVER shuts off, then there may be a stuck relay or defective sensor.
Nov 06, 2008 | Microwave Ovens
Fan problem
So is it cooking okay?
I would guess that your hood thermostat is failing.
The hood thermostat's job is to turn on the exhaust / vent / hood fan whenever the temperature above the cooktop gets too high.
A thermostat can only trip so many times before it starts to fail. Then it may come on by itself from time to time then finally stay on permanently.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
We even have a video on our site that shows you how to safely & easily remove the control panel assembly in less than 5 minutes so you can check out your oven.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 80809 Microwave Oven Logo
217 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
